Old 11-24-2014, 12:32 PM   #1
Eraser475
Eraser475's Avatar
Different shifter indicator?
My truck has a different transmission (700r4) than it had factory so the shift indicator above the column doesn't line up with anything. Is there any place to get different labeled inserts for it? Thanks
Dad's: 1973 Chevy C-60 Grain Truck 366 Big Block
Dad's: 1982 Chevy Silverado 6.2L Diesel K-10
Dad's: 1987 Chevy Silverado TBI 350 R-10
Dad's: 2007 GMC Sierra Classic 2500HD SLT
Mine: 1982 Chevy Silverado 6.2L Diesel K-10
Eraser475 is offline   Reply With Quote
Old 11-24-2014, 01:02 PM   #2
rich weyand
rich weyand's Avatar
Re: Different shifter indicator?
You have item 21 on this page. You want item 22.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=147
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 11-24-2014, 01:56 PM   #3
1774btcrew
1774btcrew's Avatar
With rebuilding steering columns, I have realized that there are also different pieces inside the column for trucks with overdrive. It is a screw in piece with notches. They are different between overdrive and non overdrive trucks. This may also effect what it is showing on your indicator
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 11-24-2014, 03:13 PM   #4
rich weyand
I suspect the detent plate was changed when the tranny was changed, or he would have noticed. The detents have to match the gear positions in the transmission and in the indicator. It is the mis-match between the detent plate and the shift indicator that he is noticing now.
Rich Weyand
1978 K10 RCSB DD.
Old 11-24-2014, 03:37 PM   #5
Jonboy
Slots go on anything!
It is pretty close even without the detent plate changed.
1974 Jimmy- 5.3/4L80e/NP241
Old 11-24-2014, 04:00 PM   #6
kalbert
Chances are the pin on the lever and the gate in the column are worn enough that you'll be able to find P,N,OD,D and 2. 1 might be just out of reach and only attainable if you loose P. Swapping the gate is no piece of cake, but its not hard just time consuming.
kalbert is offline   Reply With Quote
