Shaft kit lca
Correct me if I'm wrong, but I dropped my lower control arms off at napa to get new shaft kits put in and they installed them the same on both sides... Isn't the notch supposed to be at the front? Opposite side of the shock mount.
68 c10 |
![]() Join Date: Jan 2011
Re: Shaft kit lca
I think my pins are in the rear saddle.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Re: Shaft kit lca
![]() Join Date: Dec 2012
Re: Shaft kit lca
The dimple goes towards the front of the truck, for a 72 disc front end anyways, which mine is. I assume it is the same for your 68.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
Never Ending Projects
Re: Shaft kit lca
Here's the ones in my '68 C10. Pins in front.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Re: Shaft kit lca
They're in the front on my 89 cc dually as well.
Re: Shaft kit lca
Yeah one of mine is on the front and one on the back.
What's the reasoning for the placement in case they try to argue? |
Re: Shaft kit lca
The hole in the shaft seats over a small stud in the x-member positively locating the arm into a set position as well as helping prevent the shaft from rotating.
Re: Shaft kit lca
Yeah, if you don't have them in the right location, your shaft will not seat correctly in the saddle. The pin keeps them from rotating and from sliding forward or back.
I have seen some shafts that have these dimples on each end so they can be put in either way. I would get NAPA to correct the wrong one OR if you don't want to deal with it, drill a new dimple in the correct location. Won't hurt the shafts but make sure they are the correct location or alignment could be an issue.
#10 | |
Re: Shaft kit lca
You never know so it's worth confirming before having them re-done.
