87 blazer tank crossmember reinforcement
Guys
Im putting a efi 87 blazer tank under my 71 longbed. I have relocated the rear crossmember to the rear of the frame to make room for the tank. I have the holes drilled in the crossmembers for the straps. Do you guys reinforce the crossmembers where the straps bolt holes pass through? 175 of gas and tank hanging on those crossmembers makes me a little nervous, and i thought about tacking in some 6" long quarter inch plate as a backer on the crossmember, but wanted to know what you guys did... thanks |
Re: 87 blazer tank crossmember reinforcement
bump
thanks guys |
![]() Join Date: May 2013
should help to stiffen it, i used a 90 wrangler tank and it bolts to the crossmembers without straps
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#4 | |
All about them K’s
![]() Join Date: Jun 2014
Basically what I'm saying is that you'd only have to make mounts for the skid plate and clearance for the top of the tank. The straps mount the tank to the skid plate and the skid bolts the whole thing to the frame of the jeep. Would be pretty easy to do just by the way I've eyeballed it.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
