Old 11-24-2014, 11:00 PM   #1
trb97
Finally Got a running truck...
Been lurking forever, this is a great board. I finally bought an old truck. Been wanting one for a long time. I picked up a 63 GMC step side two weeks ago. Unfortunately, the engine blew on the way home! Picked up 350 on CL and had issues with that as well (see thread new engine, no good). We got the engine in today and it is running great.
A few issues I need to iron out:
1. The stock throttle linkage is binding so I nee an aftermarket cable. Any suggestions?
2. The truck rides like a brick! Its low! The back is notched and flipped. The PO stated that he heated/cut the front springs. I would like to bring the whole truck up 2 inches. I will be doing a disk conversion but it won't be for a while so spindles will have to wait. Not sure which direction to go. Any suggestions. I have been searching but there is SOO much info on here! The truck will be daily driven.
[ATTACH]Name:  gmc3.jpg
Size:  51.0 KB[/ATTACH]
trb97 is offline   Reply With Quote
Old 11-24-2014, 11:48 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Finally Got a running truck...
Very Nice!
66 C20 Service Truck:
Old 11-24-2014, 11:54 PM   #3
CRGRS 66
CRGRS 66's Avatar
Really nice looking truck, I agree, it is a little low for my taste too, some will cringe that you want to "raise" your truck, but it is all a matter of personal preference. Welcome to the board!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 11-25-2014, 01:14 AM   #4
Captainfab
60-66 Nut
Nice truck
I really like the satin blue and white.
You shouldn't have to change the throttle linkage to a cable, unless that is what you really want. If you post a pic. maybe we can help figure out what is wrong with it.
Changing the front springs is a simple fix for the front, but putting the differential back under the springs will raise the rear way more than 2". More like 6"+. A longer shackle and removing a few leafs will bring it back down some. You have to be careful taking out leafs as you could get some bad spring wrap on acceleration. I'm really not sure exactly what everyone is doing with leafs in the rear.
Old 11-25-2014, 09:30 AM   #5
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Great looking truck!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 11-25-2014, 12:16 PM   #6
trb97
Old 11-25-2014, 12:19 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
Lokar makes a pedal and cable that'll work on that with little mods.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-25-2014, 01:07 PM   #8
dwcardfan
dwcardfan's Avatar
I like the stance but like GRGS said its to each his own! Welcome to the forum. Lots of good info on here and lots of great people to help.
dwcardfan is offline   Reply With Quote
Old 11-25-2014, 01:20 PM   #9
trb97
I like the stance but not the ride quality!
Old 11-25-2014, 03:14 PM   #10
TJ's Chevy
TJ's Chevy's Avatar
Picture of my lokar pedal and the cable setup.
Old 11-25-2014, 09:24 PM   #11
duallyjams
duallyjams's Avatar
nice truck, shame about the engine drama.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-25-2014, 09:35 PM   #12
slowcpe
slowcpe's Avatar
Good looking truck. Stance looks great parked but I wouldn't want to drive it like that. But that's why I like air.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 11-25-2014, 09:40 PM   #13
Cape Codder
Cape Codder's Avatar
The throttle linkage pic is a little fuzzy but it appears you have the rod bolted to the carb. Unless it is pulling straight back it will need to roll as it moves. You could mount a ball stud and use the stock type link or extend the vertical arm up and to the passenger side to pull straight back.
Cape Codder is offline   Reply With Quote
Old 11-25-2014, 10:24 PM   #14
CRGRS 66
CRGRS 66's Avatar
I will have to dig and find a picture of what I did with my throttle linkage, but I used to small heim joints and a piece of.... I think 5/16 threaded Rod.
Craigerrr
Old 11-25-2014, 10:46 PM   #15
lobuck64
Here's how I did my linkage cut the top off another linkage arm drilled extra hole works great also have done one with a piece of aluminum
lobuck64 is offline   Reply With Quote
Old 11-25-2014, 11:14 PM   #16
trb97
Lobuck64, I actually did something similar to that this afternoon. Great minds think alike perhaps?
Old 11-26-2014, 11:37 AM   #17
CRGRS 66
CRGRS 66's Avatar
Here is what I did. When I had changed out the intake manifold I misplaced the clip that connected the push rod to the carb linkage, so I came up with this.
Craigerrr
Old 11-26-2014, 12:07 PM   #18
morethanstock66
morethanstock66's Avatar
I had the same issue with the throttle. I got this from jegs and saved the OEM pedal. The decision is yours, cable or rod.
http://www.jegs.com/i/JEGS+Performan...15795/10002/-1
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 11-26-2014, 12:49 PM   #19
verdell
verdell's Avatar
That's a good looking ole GMC...
verdell is offline   Reply With Quote
