Need Radio - Options for New Radio without Cutting Dash
Hi,
I have a 78 C10 with an old Cobra after-market radio that fits the original spot. The thing is garbage and I would like to replace with something with modern conveniences while not hacking up the dash at all. A few questions. - are there any good options that can be installed without hacking up the dash? - anyone install the below stereo? http://www.classicparts.com/1973-87-.../#.VHQZqye9KK1 I've searched through many historical threads and found some decent dated info but I figured out I would throw it out to you folks. Jay. |
Re: Need Radio - Options for New Radio without Cutting Dash
I've got one.
Overall, it's a good unit, simple, clean, easy to install. However, for me at least, I'm left wanting more... i.e. bluetooth, usb, more adjust-ability, etc. Been running mine for 6 years now and it's still rocking the pair of alpine 6.5's and polk 6x9's just fine. i remember seeing someone on here install a single DIN stereo under the ash-tray with one of these mounts. that's the route i want to go down the road. http://www.crutchfield.com/p_1209990...t.html?tp=2114
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
The other option is http://www.retrosound.com/
Don't Crush em Restore em
I just installed a Retro Sound Zuma model, I absolutely love it. I would highly recommend easy install and sounds great. I found some 4x10 3 way speakers on eBay to fit in the factory location in the cab corners, and bought the dual speaker from LMC for under the dash.
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually ![]() ![]() ![]() ![]() ![]() ![]() |
Thanks....
Seeing the truck (78 C10) is new to me and the stereo does not work, can you tell me where the speakers are. The only one I saw, without looking closely, is a single speaker at the top of the dash. |
Most likely that is the only one.
Trevor 74 C20...work in progress. 04 Saturn Ion...Daily Driver |
A member on here makes 6x9 cab corner speaker brackets http://www.73-87.com/Parts/7387Speak...20Brackets.htm
If you have more than one the other will be behind the seat in each lower corner of the cab. There are factory bolt in brackets that hold the 4x10 speakers. LMC sells the brackets and covers for the speakers behind the seats. http://www.lmctruck.com/icatalog/cc/full.aspx?Page=130
Roadside Rebuilder
Another option is installing one under your seat and using a remote.
Not ideal, but out of sight is always good. My buddy did a stereo, amp, and iPod holder/ hook-up under the seat of his (gasp!) '68 Ford. Speakers live under the dash, behind the bench, and in the door panels. Stock stero still lives where it should, and even works (as long as his aftermarket system is off). He had help from a local stereo-install shop, but it's a neat set up, though it does require some forethought and practice to use. |
