Old 11-26-2014, 05:46 PM   #1
heel97
64 rear torque specs
I am replacing most of the rear suspension on my 64 short bed and am looking for any info I can find on the torque specs for when putting the parts back on. I also needed to know if anyone has idea of proper torque for replacing the shock mount crossmember rivets with bolts. Have the bolts and set to bolt new crossmember in but not sure what torque range I should look for to make sure it holds as expected. Thanks for more help.
heel97 is offline   Reply With Quote
Old 11-26-2014, 05:56 PM   #2
racecougar
racecougar's Avatar
Re: 64 rear torque specs
That depends entirely on the fastener used. What bolts (size, thread, and grade) did you use?
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 11-26-2014, 06:00 PM   #3
jtrichard
http://reliabilityweb.com/index.php/..._box_training/ and another one here http://www.repairengineering.com/bolt-torque-chart.html as to your question this will answer or confuse
jtrichard is offline   Reply With Quote
