Old 08-18-2003, 03:22 AM   #1
Prerunner1982
Prerunner1982's Avatar
Question Pinion Seal? maybe? i dunno!
ok.. my truck has been leaking gear fluid from where the driveshaft meets the axle..... how hard is this to fix/replace?
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 08-18-2003, 09:40 AM   #2
RockHQ
ROCKET POWER!
RockHQ's Avatar
Haven't really looked into this but as far as i know you'll need a new crush sleeve for the pinion to set the correct pinion preload after you take off the yoke for the driveshaft. That, and a LONG extention bar to get the pinion nut off. Someone with more experience will most likely chime in.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 08-18-2003, 05:21 PM   #3
Txstruck
Txstruck's Avatar
RockHQ said it correctly, but be sure to use a torque wrench when putting the pinon nut back on as to not throw the pinion/ring gear out of whack. I had to replace mine and it took les than an hour. If I remember corectly, you will have to tap the new crush sleeve in place.
God luck! and have fun. Its not too bad
Steve
86 K30 4x4 6.2L Diesel\TH400\NP208 - 14bolt FF rear w/detroit locker and Dana60 front w/detroit locker- both with 4.56 gears "Runs on Mud"
Txstruck is offline   Reply With Quote
Old 08-19-2003, 02:46 AM   #4
Prerunner1982
will have to look at it more before i decide to do it. never messed with an axle that much before, and being my only working vehicle at the moment, i cant afford to have it down for more than a few hrs. thanks guys
Jon
Oklahoma Roll Call
Old 08-19-2003, 02:45 PM   #5
loweredd
www.loweredd.com
loweredd's Avatar
Isnt there a torque spec for using an old crush sleeve? I thought I saw that somewhere before???
loweredd is offline   Reply With Quote
Old 08-19-2003, 04:31 PM   #6
RockHQ
ROCKET POWER!
RockHQ's Avatar
I don't think a torque spec for a used sleeve will do any good, the crush sleeve is...well, meant to crush when you tighten the pinion and gives a correct preload that way?
Old 08-21-2003, 11:41 AM   #7
jimfulco
Don't forget the torque to turn is in INCH-pounds. The torque spec difference is from new bearings to used bearings.
jimfulco is offline   Reply With Quote
