![]() Join Date: Apr 2013
Frame repair question
Look for advice on the best way to repair this rust on my frame. The frame is a 72 K10 SWB. Pictures are from inside and outside of left rear. Inside rear spring hanger. I was thinking of cutting out rot and using that as template and make a new piece to weld in. Do I need to plate it also?
Thanks Nathan
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
Re: Frame repair question
hey nathan,
how are u planning on re attaching the spring hanger, being that you won't have rivets anymore after you cut them off? i would probably flush weld in a piece of 3/16th and drill holes for the hanger. then mock it up. then maybe fish plate in the back and plug weld the holes up with the hanger in place. or grade 8 bolt through one plate, or fish plate the repair spot and bolt in the spring hanger through two plates. good luck. |
Yea that's the same thing I was thinking and then bolt spring perch back in. Otherwise I think our diesel mechanic has a rivet gun. Thanks for the reply.
Nathan
The Older Generation
I would weld a patch in with the same thickness metal, plate the back a little bigger with 3/16, and bolt the hanger on with grade 8 bolts with washers. Make sure the bolts fit the holes in the hanger and frame snug. LockDoc
#5 | |
http://www.classicperform.com/Store/...ck/6372RFS.htm |
Thanks for the replies. I think I am going to double plate it.
Thanks again Nathan
![]() Join Date: Dec 2015
I know this is an old thread, but I was wondering what the outcome of this repair was. I’ve got a ‘72 4x4 swb frame with the same issue.
