I am starting to work on my old truck after many years of it resting ..My question is I think i left the wrong xmember in it ,,,????? I want to use a Tremec 5-6 speed trans ......Can I leave this on in or do I need to remove it...?? I left it in along time ago cause it looked soo structural.....does the manual mount behind it ? Tks...Glyn
![]() Join Date: Aug 2012
Re: Wrong trans x member ?
If you're talking about the crossmember that the manual tranny bellhousing rest on ...
To use a stock bell and a 3 or 4 speed trans, this crossmember can be left in and used without a rear tranny mounted crossmember. For a tranny as long and heavy as a T56, remove it and run a rear trans mounted crossmember. If you run the T56, you might also need to run the high hump floor pan section. Seems some people can get one under a low hump floor, but mine in my 66 C10 would not fit.
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
With a Tremec TKO500 or 600, I would remove the bellhousing crossmember, and install a trans crossmember under the rear of the trans. You can then also use a typical aluminum bellhousing and normal starter.
Tags |
manual trans x member |
