Old 11-27-2014, 03:21 AM   #1
mechanic350
mechanic350's Avatar
tremec t56 swap questions
so I've been searching the forum and have had some good luck finding guys who have swapped out to a 6 speed. I'm curious if anyone had bought the kit that hurst driveline sells or the kit that american power train sells and how well it worked out for you. I'm planning on mating it with the 350 i have already and possibly regearing my rear end.
1972 Chevrolet swb fleet side. - SOLD
2018 Toyota Tacoma but hunting for another C10
Link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=607303
Instagram: https://www.instagram.com/72c10shortbox/?hl=en
mechanic350 is offline   Reply With Quote
Old 11-27-2014, 05:30 AM   #2
nicolas72gmc
nicolas72gmc's Avatar
Re: tremec t56 swap questions
I was wanting to do the same thing, but just started looking at what I need to start buying for the swap. Subscribed
Nick
"Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson
1968, GMC, SWB, Project
1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components.
1972, C/10, LWB, 350 vortec, th350
nicolas72gmc is offline   Reply With Quote
Old 11-27-2014, 11:20 AM   #3
Lattimer
Lattimer's Avatar
Can't speak for the 6 speed, but I got my TKO 600 kit from American Powertrain and they were awesome to deal with. Really know their stuff and were very helpful when I had questions.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 11-27-2014, 11:56 AM   #4
BossHogg69
motor exploder
BossHogg69's Avatar
I got all the stuff for my TKO swap from these guys www.standardtransmission.com. Easy to deal with, knowledgeable and good pricing. 'Joe D.' was the guy I dealt with - I'm not sure if he still works there or not, but he knows the TREMEC line very well and was always helpful.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 11-28-2014, 12:50 AM   #5
mechanic350
great. I'm curious what ill need to get outside of what these companies are offering. sadly I'm gonna have to wait a bit before i dive into this project due to funds but I can't wait.
Old 11-28-2014, 02:21 AM   #6
kitsbeach
kitsbeach's Avatar
Curious which hydraulic clutch setup you will use.
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 11-28-2014, 11:25 AM   #7
Lattimer
Lattimer's Avatar
The American Powertrain kit for my TKO didn't come with a shifter boot. Seriously----everything else was included.
Shawn
Old 11-28-2014, 11:01 PM   #8
mechanic350
Not sure what clutch setup I'll run. Lattimer I'm liking the color of your truck. Mines the same just a 72. And thanks for the heads up. Shift boot isn't a bad part to miss out of the package when it comes to cost of getting one.
Old 11-29-2014, 12:51 AM   #9
Lattimer
Lattimer's Avatar
Thanks. Its the stock white right now, ugly, faded, dented, chipped, etc. I'm hoping to paint it next year, but still not sure on color.
I stuck with the stock mechanical clutch system and stock bellhousing since I could.
I got the street slayer clutch from American Powertrain. It has about 4000 miles on it now and I think its finally breaking in. Very tough to take off smoothly with it until it breaks in.
Shawn
Old 11-29-2014, 01:39 AM   #10
CastIron
CastIron's Avatar
What transmission did you have in there previously? Do you have the mounts on the bellhousing or rear of the trans?
It sounds like a pretty straightforward swap.
CastIron is offline   Reply With Quote
Old 11-29-2014, 07:49 AM   #11
mechanic350
Yeah I'm looking at repainting as well. Going all blacked out.
Old 11-29-2014, 11:23 AM   #12
Lattimer
Lattimer's Avatar
Originally it was a Saginaw 3-speed. I swapped in a Saginaw car 4- speed for a while. Both used the bellhousing that mounts to the crossmember. I left the crossmember in but removed the rubber mounts from it, then added the rear crossmember that was included in the kit.
The only issue I had was the hole in the bellhousing on later trucks is larger. Earlier trucks and cars have a smaller hole. Pissed me off too, because I had a bell with the smaller hole and scrapped it. So I had a machine shop make a spacer ring to take up the space. If you search there is a thread on it that gives dimensions. Otherwise its a pretty simple swap.
My understanding is the the 6-speed won't fit with the mechanical clutch linkage, you have to go hydraulic. If I was doing that I would have swapped bellhousings while I was at it. Minimal cost relative to everything else.
Shawn
Old 11-29-2014, 11:16 PM   #13
kitsbeach
kitsbeach's Avatar
I thought you had a 6-speed with a mechanical clutch linkage.?
Kitsbeach (Ken)
Old 11-29-2014, 11:33 PM   #14
Lattimer
Lattimer's Avatar
No, I have the TKO 600, which is a 5-speed. I said at the beginning of the thread I don't know the 6 speed in particular, but my dealings with American Powertrain were top notch. Their kit had everything I needed, including an adapater to move the shifter forward for the bench seat I used to have.
I wanted the 6 speed, but the trans was about $1000 more, and the hydraulic clutch kit was about $800 more, and there were a few other little things, and it looked like I needed a new bellhousing to do it right, and it was getting close to $2500 extra for the one additional gear between 4th and 5th. I couldn't justify it on top of everything I was already spending.
The close ratio 6 speed has ratios 2.66, 1.78, 1.30, 1:1, .80, .62, and the wide ratio 5 speed has 2.87, 1.89, 1.28, 1:1, .64. Pretty similar except for the extra gear.
Shawn
Old 11-30-2014, 11:39 PM   #15
mechanic350
got to spend some time with a fellow forum member and was able to discuss some of the stuff about the trans swap i can't wait to be able to do it. gonna have to wait but its gonna be worth it. search for Lss3 its a thread where 69cunningham is doing the swap we are all talking about with a ls motor bolted up. great build thread. with lots of pictures
