Old 11-27-2014, 09:39 PM   #1
AusMarty
Brake experts
Can someone please tell me where i can get one of these or an aftermarket replacement, it's off my 67 with 4 wheel power drums and is it a residual pressure valve or just a distribution block ?
Many thanks
AusMarty is offline   Reply With Quote
Old 11-28-2014, 02:18 AM   #2
Andy4639
Old member
Andy4639's Avatar
Wink Re: Brake experts
AusMarty,
I not real sure about Australia but here in the good old USA its a roportioning valve. You can get them at any parts store. The connector on top is for the brake light on the dash.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-28-2014, 02:35 AM   #3
truckdude239
truckdude239's Avatar
Re: Brake experts
I just replaced mine on my 71 had to order it off net no local stores had it. It is a portionaton vavle
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-28-2014, 08:38 AM   #4
cdowns
cdowns's Avatar
Re: Brake experts
not a proportioning valve it is in fact just a distribution block
Old 11-28-2014, 04:54 PM   #5
RichardJ
Re: Brake experts
That's actually a combination valve, but part of it is missing.
The large nut on the left is part of the proportioning section of the valve. Yours is missing that part of the valve.
The rubber cap on the right is part of the metering valve or sometimes called a hold-off valve. The center section is a valve/switch for the brake failure warning light.
The reference I found for that Bendix valve is that it was sometimes used in 71-72 A-body GM cars (Chevelle) with drum/drum brakes.
Is it possible some of your Holden vehicles with drum/drum brakes use it?
I would think that the difference between that drum/drum combination valve and a disc/drum combination valve is simply less reduction in pressure to the rear brake.
I found this web site that lists a drum/drum specific combination valve. http://www.carolinaclassictrucks.com...portion-valves
Notice that they call it a proportioning valve at the top, but in the Item Description, they correctly call it a combination valve.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 11-28-2014, 05:26 PM   #6
67 chevelle
67 chevelle's Avatar
Re: Brake experts
my guess also , especially if a wire was connected on top
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 11-28-2014, 05:57 PM   #7
mgchevyparts
mgchevyparts's Avatar
Re: Brake experts
Correct with a low pressure warning switch.
4 wheel drum vehicles do not use proportioning valves, although they do look almost the same.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
