Old 11-27-2014, 10:06 PM   #1
hdff
hdff's Avatar
Need ac info
I have decided to go thru my stock ac and repair what is broke and missing instead of going to a complete aftermarket system. My question is what is the best source to find out how everything hooks up. I think I'm missing some wires and I know I'm missing the vacuum hoses off of the controller in the cab. Other than what hangs off of the firewall I have nothing under the hood. Is a service Manuel what I need or is tHere someThing else?. Also hopefully I can find something that tells me how to remove everything under the dash and on the firewall so I can go thru it and replace a leaking heater core.
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 11-27-2014, 10:34 PM   #2
davischevy
davischevy's Avatar
Re: Need ac info
I started a thread a while back that will help you some. ANDY4639 posted a schematic that is very helpful under the dash. Just search my threads.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 11-27-2014, 10:37 PM   #3
davischevy
davischevy's Avatar
Re: Need ac info
An assembly manual will be the best source of info for getting the wires and hoses in place. For that matter, the entire system.
other Larry
Old 11-27-2014, 10:40 PM   #4
davischevy
davischevy's Avatar
Re: Need ac info
Don't forget to have your POA Valve calibrated if you change to R134.
other Larry
