Old 11-28-2014, 12:03 AM   #1
bdiamond
Hotchkis Front Shocks
I was looking into the Hotchkis front shock setup p/n 70390. It is listed as fitting 63-72.Is there a reason they aren't listed to fit the 73-87? I was wondering if fitment on stock 73-87 a-arms would be an issue? I have moved my lower forward. Does anyone forsee problems with either mounting or length?
bdiamond is offline   Reply With Quote
Old 11-28-2014, 08:33 AM   #2
Dan@Hotchkis
Re: Hotchkis Front Shocks
I'll ask our head R&D. I'm pretty confident everything would physically fit, but I don't think we've done testing/fitment on that platform.
Dan@Hotchkis is offline   Reply With Quote
Old 11-28-2014, 07:43 PM   #3
PGSigns
PGSigns's Avatar
Dan he may have the same setup as I have. A 63 to 72 with 73 to 87 control arms. I also have moved my lowers ahead. I moved mine 3/4" forward. It does bind the shock some at the bottom. I am working on a top mount that re-aligns the shock with the forward lower.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-29-2014, 09:20 AM   #4
Dan@Hotchkis
Jimmy
Interesting. Good to know and thanks for the assist!
Old 11-29-2014, 12:03 PM   #5
SCOTI
SCOTI's Avatar
Jimmy
Not sure if you considered this.... but you could put a spacer in the lower OE mount (between the tabs), use a longer bolt, & mount the shock outside/backside of the original lower mount.
It shifts the shock rearward about 1" & put's it just about where it was before the caster mod. I tried it on my CC.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-29-2014, 12:14 PM   #6
bdiamond
I was figuring I'd move the relocation bracket forward until the angle looked good. Mainly I was concerned about length. The Hotchkis setup uses a short coil and not a dropped spindle I believe.
Old 11-29-2014, 12:25 PM   #7
SCOTI
SCOTI's Avatar
The upper a-arm bushing seems like it was in the way if I remember correctly...
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
