Matching steering suspension parts
I bought a 68 C10 SWB, power steering and 6 lug drums. Then I bought a 71 C10 SWB frame with front disc and 5 lug rear end. I would like to change to 73-87 drop spindles.
I understand I would have to use 73-87 ball joints, which will fit in my 68 or 71 control arms I currently have. I understand that I will have to use 73-87 outer tie rod ends. Since the only center link I have is on the 68 truck, I understand I will have to use 65-70 inner tie rod ends. Can I connect these tie rods? Is there a simple solution for this particular arrangement? Pitman arm and idler arm were same from 67-82 as best I can tell. |
Re: Matching steering suspension parts
Well I found the answer to the tie rod mismatch. Seems I can get an adapter sleeve and move the 65-70 outer tie rod top the inner position to solve that dilemma.
Anyone see a problem with my logic on this? |
67-72 parts collector,…
![]() Join Date: Nov 2002
You are correct!!!
This is a little known fact. Most think the tie rod adapters fix everything. The 63-70 inner tie rods are RH thread. The 71-72 and 73-87 outer tie rods are ALSO RH thread. You HAVE TO move a 63-70 outer tie rod (LH thread) to the INNER location. This will allow adjustment to work with the 71-72 or 73-87 outer tie rods. I found this out when I put 71-72 spindles on my '69. The SIMPLE solution is to use 63-70 conversion spindles. DIRECT bolt on. Nothing to change. No ball joint or tie rod change. $229 almost everywhere.
Which parts would be cheaper to buy in general. 1968 parts (ball joints, tie rod ends) or 1973 parts?
Or is it all about the same? |
![]() Join Date: Sep 2007
About the same price. 73+ parts will be easier to find.
1967custom |
How's the truck coming along Neil? Any progress pics? Jim
I plan to post some update pics this weekend. Found a frame with 5 lug and front disc that I have stripped down ready to paint. Waiting on a c notch kit to come in to be installed and plan to flip the rear control arm brackets this weekend. Found the 68 frame had some minor damage after I removed the front clip also.
I am unsure about how to go about taking the cab off the frame. Is it better to remove the doors and glass first or does it matter? |
With doors and glass and seats and tank removed 2 well built men can lift it. I'd use my engine hoist with a 4x4 through the cab. Put a Block at each end to butt against gutter to keep cab from sliding side to side. Long heavy I bolt through 4x4 at each end to attach lifting chains to hoist. Save your backs, especially if things hang up. Sorry to hear about old frame. I've had a 71 or 2 frame for awhile that I bought for parts, swb. Let's see the pics. Jim
Also hope to be in on Tuesday for a few weeks of work before Christmas, might drop by and see you at the office. U1 or U2. Jim
#10 | |
Will post some pics before weekend is over, hopefully. Currently finishing up a rewire on my chevelle, and wiring for me is a slow, painful, tedious process. |
Me and my brother in-law just lifted the cab ourselves and carried it over the front of the frame. It really wasn't that heavy with everything removed
______________________ www.northeastrodrun.com |
#13 |
Also, I work in chemistry, so both units.
