Quick air hook up for rolling around shop?
While I'm waiting on all my parts I want to be able to air the truck up and roll it around the shop.
Anyone have a quick write up on what is all needed? I currently just have the bags and PTC fittings with lines running out. Thanks! |
Re: Quick air hook up for rolling around shop?
i TEE the fronts together, then use a schrader valve.. air it up like your airing up tires.
same as rear. simple. or tee them all together and then put a shop airtool fitting on the line, and plug it into the shop air
tubbed 1984 gmc jmmy http://67-72chevytrucks.com/vboard/s...d.php?t=639738 Alice Hombre http://67-72chevytrucks.com/vboard/s...d.php?t=808454 |
i used 3 tee connectors, ball valve, an adapter to the ball valve, and put an air nipple on the ball valve.
This way i can let the air out and just hook up to an air hose and fill it up when needed. |
Thanks guys. That's what I was thinking, and actually ordered everything except the valve already.
