exhaust leak question.
I have a exhaust leak between my header collector and the exhaust pipe in the drivers side. My leak was originally on the passenger side, so I got aluminum gaskets, since my copper coated paper ones failed quick. My driver side was good but like I said my passenger leaked. So I decided to replace both with aluminum ones. The passenger is good and tight, but the drivers is leaking bad. It is leaking between the top and inside bolt. Everything is tight, I even tried tightening the bolts while trick was running. I'm thinking of covering it with high temp rtv. That's what we did when I built snowmobiles. Any thoughts?
