Old 11-28-2014, 05:28 PM   #1
ACII
LS1 not starting....less fuel pressure ?
Hy all
today it was time to get the engine firing up the first time after the swap.
Unfortunately the engine is not running...
The fuel pump is running ....also i do have a spark
But i am not sure how much fuel pressure the injectors need for proper working ??
At the moment i dont have installed a fuel regulator....so the fuel just goes through the rails and back to the tank....dont know how much fuel pressure i do have ......
The engine does crank strong but there is not even a little firing..
Hope u can help me once again
Thx
Achim
ACII is offline   Reply With Quote
Old 11-28-2014, 06:03 PM   #2
79c25
79c25's Avatar
Re: LS1 not starting....less fuel pressure ?
I don't think that it will get any pressure to the injectors without a regulator.
1979 GMC Sierra Grande Crew Cab C25, 454/TH400/4.10-Project truck/ DD
1985 Chevy K5 Blazer 700r4/4.10/8 lug- in search of new engine
1993 GMC Sierra K1500 4L60E
2007 Suzuki Forenza- her DD and the family vehicle
79c25 is offline   Reply With Quote
Old 11-28-2014, 06:13 PM   #3
ACII
unfortunately i just will get the regulator during next week.....that sucks
Tomorrow i gonna check if the pcm is sending a signal to the injectors...
CU
Achim
Old 11-28-2014, 07:08 PM   #4
ls1nova71
ls1nova71's Avatar
You will have no pressure (or at least nowhere near enough) without the regulator. You can try a bit of starting fluid to see if it will fire off, just don't get carried away with it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-30-2014, 08:28 AM   #5
ACII
Hy again
in fact the fuel injectors need a specified amount of pressure for working..
I was able to press the return line together so i could reach a bit of fuel pressure...and immediately the engine fired up :-)
So i am looking forward to install the fuel pressure regulator and hopefully everything is fine..
I keep u updated :-)
CU
Achim
