11-28-2014, 09:48 PM | #1 |
Can you identify this wire?
Working on my dads '69 GMC. Sometimes it's hard to tell what is stock and what is some kluge he did at some point in the past.
Found this "hub" in the passenger side right next to the battery tray. Edit: no idea why the pic is upside down. Am posting from my mothers ipad so am limited in what I can do. Sorry The hub has 3 wires coming out of it. One goes down to the passenger headlights ( I think), 1 runs across the grill and looks like it runs through the firewall. The remaining wire is loose and dad says he thinks it goes to the battery positive. Any ideas? Thanks. |
11-28-2014, 10:05 PM | #2 |
Re: Can you identify this wire?
That "hub" is the battery junction block. As for the wire, I'm not sure. I'm sure someone will chime in with the answer shortly. Maybe try searching junction block and there may be a wiring diagram.
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
11-28-2014, 10:16 PM | #3 |
Thanks. Not used to older vehicles so just seems so odd to me. Not used to seeing extra wires coming off the battery.
11-28-2014, 10:40 PM | #4 |
Your dad is right... dads always are!
There should be a wire that goes from the positive cable to the junction block. It's actually a fusible link. Here's a picture of the battery end of the original positive cable from my 69 that shows the fusible link. |
11-28-2014, 10:46 PM | #5 | |
FirstOwner69 to the rescue once again!!
11-28-2014, 11:17 PM | #6 |
Yup. He's right. That's the link to the whole trucks electrical system.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
11-29-2014, 11:41 AM | #7 |
Thanks for the info folks. Much appreciated.
Am hoping today I can attempt to start the engine up. |
11-29-2014, 01:03 PM | #8 |
Also, make sure it is actually "fusible link' wire and not just "wire". Fusible Link is the protection from fire due to electrical short. You can buy Fusible Link wire at the auto parts store.
11-29-2014, 02:54 PM | #9 | |
RAT1968 '68 Cab/'71 Parts
But, here's the "fixed" pic.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
11-29-2014, 09:16 PM | #10 | |
Had to take a pic of my iphone from my mother's iPad in order to post that.
Brian '69 GMC C15 Inline 6, 230ci (possibly 250ci) |
