Old 11-28-2014, 10:15 PM   #1
nrasac
replacing rubber fuel line on f-pump leak
My truck (72 350 engine 81 c10) was having trouble starting and I realized that there was a small leak and abrasion on rubber hose that joins between metal fuel line and mechanical fuel pump.
I replaced it and replaced the old hose that connected to inline fuel filter and carburetor to the metal line that threads into fuel pump.
The rubber hose is held in place by hose clamps. When starting truck it was leaking by the clamps connected to inline fuel filter and fuel pump.
I was wondering if there was any sealants that I could place on metal line that would allow rubber hose to slide on and seal while using hose clamps?
I know rubber hose isn't ideal but it is what it is. The rubber hose from fuel tank line to fuel pump is about 10 in. and the two rubber hoses connecting inline fuel filter between pump and carb are 6 in. total.
nrasac is offline   Reply With Quote
Old 11-28-2014, 10:56 PM   #2
mrolds88
Re: replacing rubber fuel line on f-pump leak
I don't know of any sealer you could use for this. I know that it is what it is. I'm also not cutting on you for this. But the reason that the factory used steel lines between the fuel pump and the carb is the situation you find yourself in. Pressurized fuel may spray when you get a leak, or at least drip enough to get on many things including the exhaust manifolds. If you are using the whole setup from the 72, I would dig up a fuel line from a 68 to about 74 small block anything (presuming this is a 4 barrell Q-jet). If it is using the 81 style get something from about 78 to 86. If there aren't any good junkyards close, try craigslist for folks parting vehicles. Hope this helps.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 11-28-2014, 11:26 PM   #3
geezer#99
geezer#99's Avatar
If you're going to use rubber and you want to seal it to metal lines, just flare the tubing slightly. Poke a phillips screwdriver in the end and crank it lightly around the inside of the tubing. That'll flare (or bell) the tubing enough to let you slide the hose on and get it to seal.
Old 11-28-2014, 11:36 PM   #4
nrasac
There is no problem when sliding rubber tubing on metal fuel lines. I thought it may be problematic if I were to use sealant on metal lines when sliding tubing. Should I use different clamps for a more even seal.
Old 11-29-2014, 03:48 AM   #5
Just call me Sean
Just call me Sean's Avatar
It should seal fine. You must be doing something wrong.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 11-29-2014, 03:59 AM   #6
craig113
The metal to rubber line just needs a light flare. Where the fuel pump out to metal line is at is a compression flare, just tighten. No plumbers tape is needed.
If it a manual fuel pump its only under light pressure---7 psi
Electric tank pumps should be all steel line to engine with flare fittings because of high pressure of ---40 psi +
All returns back to tank are not under pressure and just a light flare on the line is needed.
84 K30 CC LB Fleet side 454/400/205/14 bolt Rebuilt 2200 miles
91 K15 Z71 SB 350/700r/241c/12 bolt 372k miles
96 K15 Sub 350/4L60/243c/10 bolt 333k miles
craig113 is offline   Reply With Quote
Old 11-29-2014, 04:40 AM   #7
nrasac
It is a manual fuel pump with two ports.
The rubber hose that is leaking does not have a flare unlike the fuel pump port that receives fuel from tank.
I'll try it again tomorrow and use two clamps for each connection, might use fuel injections clamps since maybe I can tighten more without fearing that clamp will cut through hose. If that doesn't work I might use a sealant like hylomar on the metal to slide tubing over along with clamps.
Old 11-29-2014, 11:06 AM   #8
donut
donut's Avatar
I wouldn't use sealer, light flair, you could double up clamps. If using worm or spring clamps, make sure the screws are offset 90-180*. (don't over tighten the clamps.)
Also make sure the steel line isn't split and your not trying to seal a 3/8" rubber line on a 5/16" steel nipple.
Other thing, you could re-do the steel line or if that isn't an option, you can get a brass, barbed nipple and use that off the pump.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 11-29-2014, 12:23 PM   #9
SCOTI
SCOTI's Avatar
This is what I was wondering. Easy thing to overlook/assume....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-29-2014, 12:34 PM   #10
jetmech85
I used all Summit parts starting at the fuel pump with a 5/8 inverted flare to -6 an fitting then a 90 degree an to cloth braided hose up to a -6 an fuel filter then to carb with the proper fitting. No clamps and no problems. Seems like it was in the $40 range. I know its more than a cut fuel line with an inline fuel filter and clamps, but I feel safer. If I use an inline filter with rubber hose and clamps I try to install it before the fuel pump on the suction side without cutting metal lines. Hope this gives you a few ideas.
jetmech85 is offline   Reply With Quote
Old 11-29-2014, 08:50 PM   #11
nrasac
While I doubled clamp the hoses and it stopped the leak. But, I had to use 4 inches of the old hose. So, as soon as rejuvenate from Thanksgiving, gotta replace it.
One other thing,my inline filter reads 3/8, but I am thinking that maybe 5/16 would fit on barb or possible switch to a 5/16 filter. The port on fuel pump looks like it is 5/16.
thanks for info.
