11-29-2014, 12:13 AM | #1 |
CPP disc brake conversion and lowering kit quality
I am looking at the CPP power disc brake conversion kit for a 70' C10 LWB, will do the 21/2" lower spindles along with 1" front and 4" rear lowering springs at the same time.
Looking for a good opinion on the quality and completeness of the CPP kit and if the are any other upgrades that should be made at the same time. (Doing power steering conversion this Winter) Thanks in advance, great site has been a big help on answering all of my questions. |
11-29-2014, 01:17 AM | #2 |
Re: CPP disc brake conversion and lowering kit quality
I just installed this in my 67. I would def recommend buying a different prop valve and not use the one that comes in the kit. I took a board members advice and bought a Wilwood one. Cost me $100. If you buy the grand slam kit, I got mine from Summit Racing. Was cheapest I found and free shipping.
11-29-2014, 01:18 AM | #3 |
Oh, you'll have to get rear shock relocators and adjustable panhard bar as well. Got those from cpp's ebay store.
11-29-2014, 10:29 AM | #4 |
Junior Member
What problem did you have w/CPP prop valve?
11-29-2014, 12:19 PM | #5 |
I'd say there stuff is fair quality for a fair price. Most will recommend Ece vs cpp which in my opinion is excellent all around.
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly |
11-29-2014, 12:33 PM | #6 |
The metering valve failed on mine causing it to spray brake fluid from it. Replaced the metering valve 3 times and same thing.
11-30-2014, 04:46 AM | #7 |
Old member
I didn't buy the front brakes since the 71 already has them but I did buy their rear disc brakes. I wouldn't recommend them for the rear.Checkout the link of the install. I got them working but I think you be better off with someone elses kit.
http://67-72chevytrucks.com/vboard/s....php?p=6902266
11-30-2014, 07:15 AM | #8 |
Thanks for all of the feedback. I think I will give ECE a call and assemble a full kit to compare, it sounds as if it is better quality without the foreign made parts and far better service!
11-30-2014, 12:21 PM | #9 |
Moderator
Have all CPP lowering stuff on my truck. Zero complaints and would buy again.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
11-30-2014, 12:25 PM | #10 |
Same here. I also have a CPP Booster, master, proportioning valve combo and it all works great.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
11-30-2014, 01:04 PM | #11 |
Catchy title goes here..
my suggestion is to read the review forum. There are quite a few threads on both companies
