Old 08-18-2003, 11:24 AM   #1
dubie
dubie's Avatar
cam specs question
Is this a fairly lumpy cam? I don't really know how to read cam specs
Intake
open 42 before TDC
close 78 after BDC
Cam lift .298
valve lift .448
Valve dish .030 Hot
Exhaust
open 78 before BDC
close 42 after TDC
cam lift .298
valve lift .448
valve lash .030 hot
Can you guys shed some light on how to read these specs and let me kow if this is a nice sounding cam
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 08-18-2003, 11:31 AM   #2
Randy70C-10
Randy70C-10's Avatar
Do you know what the LSA is? That cam sounds like it might have a little lope to it. I'm assuming that the 298 is the duration?
Randy70C-10 is offline   Reply With Quote
Old 08-18-2003, 11:31 AM   #3
jhwkns
Registered Cruiser
jhwkns's Avatar
What are those specs. from. Is that an OEM solid cam?
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 08-18-2003, 12:38 PM   #4
bpmcgee
bpmcgee's Avatar
Wow,
If I'm reading that right, the exhaust opens 78 BEFORE BDC, and the intake CLOSES 78 AFTER BDC. That would give you 156 degrees of overlap!!!
If I'm reading that right, this is one DOOSIE of a lumpy cam! The mild cams I'm looking at have about 35 degrees of overlap!
Brian
bpmcgee is offline   Reply With Quote
Old 08-18-2003, 12:49 PM   #5
70c10
67-72 Addict!
70c10's Avatar
Tim, It sounds like 292 duration but that seems high for a lift of .448. Maybe it is a solid cam, I don't know. The idle Lumpiness is from the LSA that Randy mentioned. I believe most of the sound is from the duration under acceleration. What brand cam is this?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-18-2003, 01:02 PM   #6
Ackattack
Ackattack's Avatar
I'm guessing it's a solid lifter cam since it has lash adjustment specs. The cam lift is how much it lifts the lifter (.298"). Multiply that by your rocker ratio (stock SBC is 1.5) to get valve lift (.447")
duration at .050 lift and LSA would help out.
Ackattack is offline   Reply With Quote
Old 08-18-2003, 01:03 PM   #7
dubie
dubie's Avatar
It's an Iskenderian racing cam. These are the specs from the cam that is in the 283 I just bought for Shawnas 67 GMC project.
Old 08-18-2003, 01:07 PM   #8
dubie
dubie's Avatar
here is a scanned copy of the specs tag
Old 08-18-2003, 01:18 PM   #9
jhow66
jhow66's Avatar
Cam has 32* of overlap at .050 lift( In. open-Ex close) And 248* of duration at .050 lift. Should be ok for your 283 with some "sound" to it.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
