Old 11-29-2014, 02:10 PM   #1
BSimmons
Dash light help
This light is wired into the harness behind the dash consol. It has a white holder and looks like is should connect to the back. The dash has been out many times over the years. It was obviously left disconnected during some previous project. All light sockets are currently occupied whether they should be or not. Could this be the park brake indicator?
BSimmons is offline   Reply With Quote
Old 11-29-2014, 02:18 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Dash light help
That is the socket that illuminates your shift indicator on the steering column. It can be placed in any of the 4 locations that illuminate the cluster lighting.
It also has (the black tube) is which is a fiber optic that runs up th column to the shift indicator. If it is kink, it will not work.
Hope this helps,
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 11-29-2014, 02:48 PM   #3
BSimmons
Re: Dash light help
Thanks Tom!
That makes perfect sense. I converted it to a 4 speed about 20 years ago. It is left over from before the conversion.
Bryan
Old 11-29-2014, 03:37 PM   #4
BKSS67
Re: Dash light help
Do all 67-72 auto tilt columns use this form of shift indicator illumination?
Are there differences between the years and whether it was a standard or tilt column?
BKSS67 is offline   Reply With Quote
Old 11-29-2014, 03:48 PM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Dash light help
That is a good question. I am not 100% sure what years have what but my simple answer is no. I believe some shift indicators do have a bulb at the indicator powered by a wire with battery voltage.
Old 11-29-2014, 04:52 PM   #6
john
member #16
john's Avatar
Re: Dash light help
correct, the tilts have a bulb.
john is offline   Reply With Quote
Old 11-29-2014, 11:16 PM   #7
kcsa75
kcsa75's Avatar
Re: Dash light help
Not to hijack this thread, but do you know what color wire connect to voltage to power this bulb. I've replaced the bulb but it still doesn't work. I have black wire from the column that is not connected to anything.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 11-30-2014, 01:04 AM   #8
BlacklandCamper
Re: Dash light help
How do you tell if a truck had tilt originally? My C20 has that same bulb and socket, but a non tilt column.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline   Reply With Quote
