Old 08-18-2003, 12:49 PM   #1
67pro-street
67pro-street's Avatar
where does the gas tank go???
i am putting a suburban gas tank into my 67 long fleetside. i was just wondering whrere the tank straps connect onto the chassis and where the actual tank is supposed to be fitted. i would have used the search function, but it has been disabled for quite a while?? does anybody know when it is going to be up and running again?? anyways, any help and pictures would be greatly appreciated.
67pro-street
67pro-street is offline   Reply With Quote
Old 08-18-2003, 12:57 PM   #2
Mudder
Mudder's Avatar
crossmembers
I made new cross members for my tank and skid plate. The skidplate actually helps to hold the 33 gallon tank up. Don't know if you can tell by this picture.
Mudder is offline   Reply With Quote
Old 08-18-2003, 12:58 PM   #3
Mudder
Mudder's Avatar
heres another
Old 08-18-2003, 01:27 PM   #4
72longbed
72longbed's Avatar
Mudder67,
If I'm seeing things correctly, you located your Suburban tank at the end of the frame rails? How did you route the filler neck for this location?
72longbed
72longbed is offline   Reply With Quote
Old 08-18-2003, 01:29 PM   #5
Mudder
Mudder's Avatar
its in the very back of my bed and I'm using a boat filler so its flat with the floor. I have seen others that work well. Remember I do have a body lift under my bed of about 2 1/2 inches.
Old 08-18-2003, 01:32 PM   #6
Mudder
Mudder's Avatar
Lots of ways
to run a filler. Stano ran his into a door on the bedside.......looked really good.........here's a street rodder truck fill that is a local truck. This one you can put gas in without taking the cap off.
