new valve covers and wire hiding.
So here are my new aluminum valve covers. I love them they look so cool. I think they make no motor look like a race truck. I had chrome edelbrock ones that kept leaking cause they were warped. So I spend $60 on the valve covers and $20 on some steel/rubber reusable gaskets. The passenger side went on easy, but the drives was a different story. I had to dent in the fire wall just a little in order for it to fit the taller gasket and covers. They are baffled and came with bolts and washers. I also routed my spark plug wires under the headers and behind the covers. Made it look really clean. Only one on each side I want able to move. I'm sure I could if took the time to switch wire lengths. But other then that I'm pleased. What do you think?
Re: new valve covers and wire hiding.
I like 'em too. Interesting fan you got there. It's a clutch/flex hybrid.
I've got a mark viii fan to put on, just haven't got the wiring done yet.
i bought a set of moroso "under header wires" from summit. made for a very clean look i think.
Davbowen, that looks super clean. What fan shroud are you running?
thanks lmc truck replacement shroud. fit perfect. has 2 sets mounting holes 6 cyl and v8. i placed it based in where the fan was.
Those are $$$. But it sure looks great.
![]() ![]() Join Date: Aug 2013
Now know what the 2 pieces of sheet metal I have left over do...hold the fan shroud in place like yours
Nice valve covers j.rigby. Makes it look almost like a big block.
A word of caution on plug wire routing: it's better to use separators instead of zip ties and be especially careful of the #5 an 7 wires running parellel. Because of the firing order they can crossfire. |
#11 | |
![]() Join Date: Apr 2009
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
#12 | |
#13 |
#3 wire is actually pretty far from the header, it is more of an optical illusion, I think. LOL I will have to double check but I am sure it was when I took the picture. Thanks for looking out. Sometimes I miss stuff when I get excited, tired, or just simply open the hood.
#14 |
Post Whore
![]() Join Date: Mar 2013
X2, Be careful with your wires being under the headers.....that's where they came out with ARCHology. LOL!!! HAHA! I'm running a 6 banger so my wires are a mile away from the headers...Diggin the valve covers!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#15 |
TJ'S chevy, thanks for the advice. I do recommend this style of valve covers. I would encourage you to make sure you have enough clearance all around the valve cover. They are a lot taller then normal covers, especially on the back side against the fire wall.
