Old 11-29-2014, 09:11 PM   #1
vht
Rear suspension help, again
I posted on here awhile back about building my own trk style rear susp on a street rod I'm building. I have searched for the thread but have had no luck. There was 1 guy building his own, was wondering how it worked out. Anyway, I started on my frame, to get a break from body work, and almost got the front susp done. Need to get the rear done so I can set the body on. It has a 115 WB, do you think a 5 ft arm would be about right? Rough measuring shows it would put me about a ft or so behind the trans crossmember. Maybe a little closer. Also has anyone seen anything on building this set up? I have googled everything and came up with very little. I was planning on going with 2x2, 1/8 in box tubing, will this be stout enough? I'm going with coil springs also, with a long adjustable panhard bar. Any info or pics would be great. I'd like to start on this in a wk or so. Also I seen on here somewhere where I think 69restomod built his own antiroll bar. I would think that would help also.
vht is offline   Reply With Quote
Old 11-30-2014, 03:07 AM   #2
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Re: Rear suspension help, again
Can't help with your suspension but,
Here is a link to all the threads you have started LINK
You can find this info on any user by clicking on their name and going to the 'statistics' tab and 'Find all threads started by'
Ghostwhite is offline   Reply With Quote
Old 11-30-2014, 03:51 AM   #3
vht
