Old 11-30-2014, 01:30 AM   #1
shortbed70
shortbed70's Avatar
Tire recommendation???
I'm going to be running 17x8 wheels on my 65 but am at a crossroad on what tire to run!!! 225-45-17 235 or 245-45-17.. I'm afraid the 245 will be to wide and hit the bedsides and would really like pics of these combos.. My truck is bagged so it ticks the wheel a bit in te back..
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 11-30-2014, 12:17 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Tire recommendation???
I'm running a 295/45/18. With side to side movement going around corners the tire kisses the bubble on the rear tub. 1/4"
http://67-72chevytrucks.com/vboard/s...d.php?t=635064
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 12-05-2014, 11:22 AM   #3
shortbed70
shortbed70's Avatar
Guess the wheels are 18" not 17's.. So that works well.. Thanks. What backspacing you have
Troy
Big Red Dog build
Old 12-05-2014, 11:34 AM   #4
LVPhotos
LVPhotos's Avatar
4.5" with the 67/72 rear, fronts should be same only 1" narrower. The tire on front is 235/60/15, new pictures have a 225/70/15 which is taller and closer to 245/45/18 I plan on.
http://67-72chevytrucks.com/vboard/s...d.php?t=651855
