427 tall deck in a 1979 K25 GMC
I'm in the process of rebuilding a 427 tall deck to put in my K25. I am trying to find out if I can*use the 13" clutch assembly and flywheel out of the C70. Also if there is a dual plane low rise intake for the tall decks, so I don't have to use the spacers. And will the radiator out of a 2 ton fit in my truck. Also header fitment. The truck will be used to pull a stock trailer and as a wood truck. So the setup should work good as long as everything fits.
