11-30-2014, 06:50 PM | #1 |
lmc truck lowering block
Lmc says the lowering blocks are not recommended for 15in wheels why
1970 chevy short box c10 factory 402 big block with AC 2008 chevy silverado regular cab short bed lowered 1990 454ss 52,000 miles 5/6 drop |
11-30-2014, 07:29 PM | #2 |
Re: lmc truck lowering block
too much of a lowering block can cause the suspension to be lower than the rim in the case of a flat tire. a larger diameter rim potentially won't have this issue.
11-30-2014, 07:30 PM | #3 |
I think if you get a flat tire your trailing arm will be on the ground.
11-30-2014, 07:39 PM | #4 |
My understanding is that a lowering block larger than 1.5" will cause the u-bolts to scrub in the case of a flat...
Maybe someone that has run blocks and 15s will chime in. |
11-30-2014, 11:38 PM | #5 |
Got 2" lowering blocks on my Willys...15" wheels....no problem ever.
12-01-2014, 12:09 AM | #6 | |
The dif sits on top of the trailing arms and the trailing arms are pretty tall. If the blocks are too tall the bottom of the u-bolts will be below the rim in the event of a flat tire.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
