Old 11-30-2014, 08:49 PM   #1
Kungfoogrip
Kungfoogrip's Avatar
What would you do?? (dash bezel)
Ok here goes....my 71 instrument cluster originally just had the speedometer and the fuel gauge on the sides and in the center was the alternator and turn signal indicators. The PO cut two holes in the bezel for an after market oil psi and water temp gauges. Pretty crappy looking if you ask me. So my question is I want to get new bezel but I am not sure which one I should get. Should I go back original or should I add some gauges and get the bezel accordingly. If i am going original I am seriously considering getting the new printed circuit and instrument lens. So what would you guys do? I am also installing my new wiring harness from AAW.
Kungfoogrip is offline   Reply With Quote
Old 11-30-2014, 08:54 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: What would you do?? (dash bezel)
Get a 7 gauge cluster and change it over in the wiring and motor senors. You will be much happier with it in my opinion.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-30-2014, 09:07 PM   #3
FirstOwner69
FirstOwner69's Avatar
My truck had the 3 hole idiot light gauges also. Below area couple I did. If you go the factory 7 hole route you'll have to make some wiring changes as described here http://gmcpauls.com/Tech%2520Tips1.htm
FirstOwner69 is offline   Reply With Quote
Old 11-30-2014, 09:31 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'd upgrade to OEM gauge cluster as above. You could pay to become a Premium Member of the site and post WTB ad for the correct OEM harness and gauge cluster - not hard too get and a relatively inexpensive route.
Old 11-30-2014, 09:39 PM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
Let me know when you are ready and I can take care of all of your cluster needs as well as assisting with wiring changes that need to be done. I specialize in 1967 - 1972 Chevy/GMC gauge cluster restoration and repair. I also sell parts .
I also suggest you pay for a membership here. Best $25.00 you will spend.
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 11-30-2014, 09:43 PM   #6
Kungfoogrip
TBONE pm sent. thanks
Old 11-30-2014, 11:00 PM   #7
davepl
davepl's Avatar
I believe LMC and maybe Classic Industries sell entire turnkey setups with all gauges, PCB, and so on. Not cheap (over $700 if I recall, but check).
I can recommend TBONE as being a great guy to deal with and if he's got what you need, or can get it, the way to go. May be other vendors too, he's just the one that helped me out with a Speed Warning cluster issue and it was a good experience.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-30-2014, 11:12 PM   #8
Nitis
Nitis's Avatar
Getting ready to tackle this project on dad's truck.
Op sounds like the buggies part is done already seeing you have a temp gauge and oil gauge you may be able to use those supplies to your new gauge cluster
Nitis is offline   Reply With Quote
Old 11-30-2014, 11:13 PM   #9
TBONE1964
Cluster King
TBONE1964's Avatar
PM returned
Thank you
Tom
Old 11-30-2014, 11:14 PM   #10
TBONE1964
Cluster King
TBONE1964's Avatar
I apprecaite the kind words Dave. Thank you
Old 11-30-2014, 11:31 PM   #11
Kungfoogrip
Lets get the ball rolling TBONE...PM sent Thanks!
Old 11-30-2014, 11:44 PM   #12
Nitis
Nitis's Avatar
Does anyone offer a plug in adapter to avoid re routing the wires? Just unplug from the three hole plug into adapter that reroutes things and plugs into 7 hole bezel?
Maybe the wiring is just so simple? And this won't avoid the hardware needed to get the temp and oil working right
Old 11-30-2014, 11:52 PM   #13
TBONE1964
Cluster King
TBONE1964's Avatar
It is not actually re routing the wiring but re pinning the warning light cluster connector to work on a gauge cluster. The connector for both gauge and waring light clusters is the same. Some of the terminals will need to be switched in the connector and some wiring will need to be added for the amp gauge.
Hope this helps
Tom
Old 12-01-2014, 12:17 AM   #14
Nitis
Nitis's Avatar
Yeah we went over that diagram several times today. Which is why I though a little plug deal might be out there. Thx
Old 12-01-2014, 01:02 AM   #15
heathbirkendahl
Looking to do the same to my 71' with white gauge face. Anyone have pics they can share?
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 12-01-2014, 01:18 AM   #16
TBONE1964
Cluster King
TBONE1964's Avatar
It would be nice if there was a female connector to mate with the male connector that plugs into the cluster. That would make it a simple plug and play. Unfortunately, there is no such connector.
I have a how to in the electrical section of this forum on how to re pin the connector.
Old 12-01-2014, 01:24 AM   #17
TBONE1964
Cluster King
TBONE1964's Avatar
Here are some photos of a couple of white face conversions that I have done for other customers.
I received your PM and will respond to you soon
Take care,
Tom
Old 12-01-2014, 02:20 AM   #18
heathbirkendahl
The bottom one is exactly what I am looking for. This would be a direct replacement minus adding the wiring for the tach, correct?
Thank you,
Heath
Old 12-01-2014, 02:29 AM   #19
TBONE1964
Cluster King
TBONE1964's Avatar
Thank you,
Heath
That would be correct Heath if you already have the standard gauge cluster (amp, temp and oil pressure gauges). The tach uses a separate harness and I also make them in my shop as well.
Thank you,
Tom
Old 12-01-2014, 02:51 AM   #20
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Gotta ask about sourcing a clock like in post #3 for my set-up.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 12-01-2014, 03:11 AM   #21
Andy4639
Old member
Andy4639's Avatar
Wink Re: What would you do?? (dash bezel)
I got mine out of a 80"s model Chevy truck. I lost the second hand on the clock but it worked. Tbone redid this one also before I sold it.
Old 12-01-2014, 07:15 AM   #22
jjzepplin
jjzepplin's Avatar
Subbing for the conversion info. I have a four speed harness with idiot lites that I want to put a tach and gauge cluster in. I see the amp gauge needs extra wiring.
Does anyone pre-make this wiring?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 12-01-2014, 12:14 PM   #23
TBONE1964
Cluster King
TBONE1964's Avatar
I don't think anyone is making a pre made wiring kit for this JJ. You have to add it in or just buy the correct wiring harness for under the hood and dash.
It is only two wires and you can find there location on a factory wiring diagram. I know one ties in to the little junction box near the battery and the other one goes to the alternator.
Hope this helps.
Tom
Old 12-01-2014, 12:16 PM   #24
magwakeenercew2jh
Thanks, Andy.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 12-01-2014, 02:14 PM   #25
mrein3
mrein3's Avatar
To add on to the clock part of this thread:
Look in 80's model trucks. I got mine out of a Suburban. Around here Subs seem to be better equipped so if your yard has a row of trucks and a row of subs, I start with the Subs.
To make a hole in the clear plastic, measure twice, then use a heated nail. I picked this nifty trick up on this board about 10 years ago.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
