transmission shift lever
Has anybody here removed the shift cable from the transmission shift lever, Im asking this because mine fell off the other day and stranded me. I'm wondering if it is a clip that came off. I ordered a new lever just waiting for it and hopeing it comes with a clip. I took the lever off today and the stud is pretty corroded. I can't believe what the road salt here in massachusetts is doing to my 2003
Re: transmission shift lever
There isn't a clip that holds it on. It just pops on and off. The plastic in the end of the cable may be stretched. Might be time for a new cable.
Ok, thanks for the reply. I guess I have to hope the new lever fits tight.
Vehicle description may help with answer you are looking for.
04 Yukon XL 2500 w/ Quadrasteer ![]() 61 Chevy C60, 261 inline six 86 Chevy C20 2wd, Banks 6.2 05 GMC Sierra 2500hd Duramax |
I just realized I didn't post an update to the situation. It is a 2003 silverado 5.3. I ended up taking the shift lever off cleaning it up painting it drilling about a 1/8 hole through the stud and used a stainless bolt and 2 lock nuts and used a nickle as a washer. my issue was the shift cable was worn I think ( its been a while) the plastic clip was worn or broken so I didn't want to replace the shift cable. the repair seems solid and so far no issue. thanks for the info above
