Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 11-30-2014, 09:33 PM   #1
Puke160
427 tall deck
I know it's not in the right post but figured you guy knew the most about this motor. I'm in the process of rebuilding a 427 tall deck to put in my K25 GMC. I am trying to find out if I can use the 13" clutch assembly and flywheel out of the C70 on the Muncie 4 speed that is in the truck. Also if there is a dual plane low rise intake for the tall decks, so I don't have to use the spacers. Also header fitment or do I have to use the stock manifold. The truck will be used to pull a stock trailer and as a wood truck. So the setup should work good as long as everything fits.
1949 Chevy C3100
1979 GMC K25
1982 Chevy C20
2000 Chevy K2500
2002 Pontiac Trans Am
Puke160 is offline   Reply With Quote
