Old 12-01-2014, 02:50 AM   #1
BossHogg69
motor exploder
BossHogg69's Avatar
Got the cab on, now what? Experienced Frame-Off gurus step inside...
Got my cab set down on the frame this weekend, now I'm trying to plan my next steps. I have been looking at MANY of the build threads to see how/what/when others are doing things, but I figured I'd post it up for discussion. I have all the parts already - wiring kit, interior pieces and all the underhood stuff.
My plan was to lay down the Dynamat inside the cab, then mount the brake & clutch master cylinders on the firewall, plumb the hydraulics (brakes/steering) under the hood then jump back inside and install the wiring harness inside, wire the engine and finish out the interior. Then install the fenders, hood and doors.
I just want to go in an order where I'm not fighting myself having to take stuff back apart due to doing things out of order. There is a pile of parts sitting in my garage so it's hard to resist the urge to just start bolting crap on just to see what it looks like. I want to be more efficient at this stage in the project so I can be driving this thing come spring of 2015.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 12-01-2014, 08:13 AM   #2
68shortwide
68shortwide's Avatar
Re: Got the cab on, now what? Experienced Frame-Off gurus step inside...
D@mn that trucks pretty what colors that?
Jack
1968 swb on air
68shortwide is offline   Reply With Quote
Old 12-01-2014, 11:58 AM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
PPG Deltron 'Tungsten Metallic'.
Adam
Old 12-01-2014, 12:07 PM   #4
big d's red67
big d's red67's Avatar
I'm sure everyone has a different way to do it. When Mine was at the place yours is I started by putting the doors on, then put all the glass back in it followed by the everything on the inside i.e. Steering column gage cluster etc. then sent it over to have the wiring put in it.
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Old 12-01-2014, 12:22 PM   #5
71 super
71 super's Avatar
The steps i use are as follow. Interior- put everything that can be chunked, Heater ducts etc. together before hand . Start at the dash pad and work down and out. From pad do the wiring and then radio and heater. Run ducting and dash cluster. From there glove box and column and emergency brake assembly. From there install carpet dome light seat belts and then gas tank. Install seat then doors and and window regulators. Install glass loosely and then install vent windows, followed by weather striping. On engine bay run engine harness across firewall and hook up starter etc. Install outside heater box if not already complete with interior stuff. Run headlight harness and hook up at core support. Install inner fenders next- the cab will square core support via the inner fenders. Install all of this loosely. Install outer fenders based off of doors and adjust as needed. Install hood latch, hood hinges and grill. Install front bumper. Front assembly should be complete or very close from this point. Hope this helps.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 12-01-2014, 12:46 PM   #6
72 tigger
72 tigger's Avatar
Good advise! I would wait on installing the doors until the interior is nearly done so that you don't have to work/walk around them all the time. Nice truck by the way!
72 tigger is offline   Reply With Quote
Old 12-01-2014, 02:25 PM   #7
bs46488
Wow she is SEXY!
Too bad you have to "finish it" and can't drive it like that!
bs46488 is offline   Reply With Quote
Old 12-01-2014, 02:31 PM   #8
bterry97gt
Did you use a matte clear? Love the finish
bterry97gt is offline   Reply With Quote
Old 12-01-2014, 02:42 PM   #9
69moneypit
Divorced .....WITH KIDS
69moneypit's Avatar
What size rear tires and brand ?
1969 GMC SWB
1975 Chevy Malibu 80k
1963 Ford Galaxie 63k (inherited)
2005 Nissan Armada (wife's idea)
69moneypit is offline   Reply With Quote
Old 12-01-2014, 07:40 PM   #10
BossHogg69
motor exploder
BossHogg69's Avatar
Thank you for the detailed response! That's the kind of outline I was looking for.
I had planned to put the doors on after the bulk of the interior work was finished since I'm working out of a two car garage packed with all my tools and parts to keep from hitting the doors on something and messing them up.
Originally Posted by bs46488 View Post
Wow she is SEXY!
Amen to that - I can't wait to get this junk pile on the highway!
Thank you - matte clear on the interior & underhood. The outside and door jambs are gloss.
BF Goodrich KDW 335/35/18
Adam
Old 12-01-2014, 10:16 PM   #11
Possmguts
Possmguts's Avatar
damn, shes gonna be a beautiful girl.. nice color choice!
One question with the smoothed firewall, what are the 4 tubes sticking out? Is that heat and air hookups?
What suspension did you use?
Ok that was two questions...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 12-01-2014, 11:14 PM   #12
DonnieB
Very nice man! Keep the progress pics coming
DonnieB is offline   Reply With Quote
Old 12-02-2014, 12:26 AM   #13
BossHogg69
motor exploder
BossHogg69's Avatar
Yes, the bulkhead is for the heat & air. As for the suspension, its a mix of CPP & Hotchkis with an '86 Camaro IROC-Z rear bar and some homemade stuff thrown in to keep it interesting.
Here's a better pic of the paint color on outside of the body.
Adam
Old 12-02-2014, 01:15 AM   #14
hpcgmc
hpcgmc's Avatar
71 Super, great info on putting the truck back together. I'm hoping to be ready to put things back together this spring and I'll bookmark this page for sure! Great question Boss. That color and smoothed firewall look great!
1967 GMC 1500 SWB. Driving this truck since I was 14.
hpcgmc is offline   Reply With Quote
Old 12-02-2014, 01:18 AM   #15
68shortwide
I think I found the color of the 67 Camaro..... Lookin good man.
Jack
1968 swb on air
Old 12-02-2014, 01:26 AM   #16
michael bustamante
michael bustamante's Avatar
And i ALMOST went with that color too but the orange grew on me... well that and my og firewall paint polished up real pretty.
Did you customize the rad support or buy it like that?
1967custom
michael bustamante is online now   Reply With Quote
Old 12-02-2014, 01:26 AM   #17
BossHogg69
motor exploder
BossHogg69's Avatar
here's a pic with some sun on it. As for the core support, it's stock, but I took a couple hole saws and some dimple dies to it.
Adam
