I have a small block 350 in my 1986 GMC Sierra 1500. Which would you prefer? Headers? or Manifolds? and why you would choose them? Thanks for the input.
Re: Debate, Headers, or Manifolds
Manifolds. I don't think the tiny gain is worth the expense of headers.
Depends on what you want.
- Manifolds are cheaper, because they are the stock item, and you can get them used cheap. - Manifolds are easier to hook the heat stove to for the thermostatic air cleaner. - Manifolds won't rust out for the lifetime of the vehicle. - Headers give a cooler sound. - Headers give about a 20% increase in both torque and horsepower. In my setup, the engine output goes from 240 hp @ 4000 to 285 hp @ 4000, and torque goes from 355 lbft @ 2500 to 422 lbft @ 2500, or an increase of 19% in both. That's a big increase for a couple hundred bucks and not having to tear into things very far to do it.
Rich Weyand 1978 K10 RCSB DD. |
Post Whore
![]() Join Date: Aug 2014
this ought to be a good one, let me pull up a chair
headers are better if you want braggin rights and have something to add to your forum signature (LOL) headers also may be lighter manifolds are better in terms of fitment and replacement of gaskets with the engine in the car |
#5 | |
Post Whore
One would think that changing one component of the system such as exhaust would by itself yield no benefit unless the complementary input component such as carb or jetting or intake was changed / tuned / ported as well. Did you do any of those other things too? |
At the body shop.
If you want painless headers.
Plan in spending $5-600
" That didnt make it any newer " " Dont antique the equipment " |
78K & 79C Jimmys
running a Stock block?,and drive during the winter,less maintenance.
you can clean manifolds up and get a little more noise/flow out of them. just clearing up the insides can make a difference, getting rid of the noise disturbing bumps in the stock manifolds.
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
It was actually cheaper to go with the edelbrock t.e.s. emission legal headers then to replace the cracked manifolds in my k10. Being California I have to have all the smog tubes and thermostatic housing to pass the visual test. The passenger side manifold new with the stove pipe was 300 bucks alone. I couldn't find it used in 2009 when I needed it. The driverside I had no problem finding. But that still ran 125 new. The yes headers cost $399 and were shorties but coated. I will say spark plug changes are much easier with manifolds as getting to them with the headers is a pain.
driving is in my blood
That's a very one dimensional thought. Tiny gain on mustangs that come oem with short tube headers? Yup. Tiny gain on a 73-87 with any kind of mods done? Not at all. Even stock its a nice improvement percentage wise. Still not worth it to some, but to call the gains tiny is wrong.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
#10 | |
Simulation was done with generic 600 cfm carb, but with a dual-plane (i.e. not stock) manifold.
Good questions, and one I've been asking myself as well.
I have an '85 Suburban with stock manifolds right now. I removed all of the smog fittings and plugged them with cummins drain plugs. I've already purchased an aluminum intake and Summit (Holley) 600cfm carb. I'll be going to 2.25" dual exhaust and am now deciding on whether to go with stock manifolds, shorties or full length headers. I'm not sure about the full length since I'll be lowering the front suspension. Are shorties worth it?
Romans 10:9 - The Truth |
Simulator says you get about 3/4 of the gain of long-tube headers (over stock) when using shorties.
#13 |
Roadside Rebuilder
What about some Ram's Head manifolds?
I imagine they'd fit in a truck fine, and they're reputed to be the best of both worlds: Better flow, cast iron. I have no experience with them personally beyond what friends have done, but they come highly recommended. Speedway has a pretty nice looking pair, and I think they're the same one's my buddy put in his Impala. |
#14 |
I have LT1 exhaust manifolds out of a 96 Caprice on my 81 C20.
Eric 2001 Ford F350 EC dually 7.3 1981 Chevy C20 to K20 350 1978 Oldsmobile Cutlass Supreme 455 Pontiac 1969 Pontiac GTO 400 |
#15 |
What ever's the easiest for you. My plow truck had headers, as it was 40 miles to an exhaust shop that could bend the pipe. Summit exhaust kit made it legal to drive.
Current truck has headers as it was much cheaper and less of a pain to repair all the exhaust leaks. Smog tubes were also seized in the manifold, soooo sawzall time. This one's also a 454, so smog tubes were pretty good size and extended into the exhaust port of the head. Capping wouldn't have fixed that. I did try to keep the manifolds on both trucks, though it would have been a bunch more work.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
#16 |
78K & 79C Jimmys
I grind them smoother
#17 |
![]() Join Date: Oct 2013
Just my option!!
Depends on how you use your truck? Daily driver manifolds, more of a fun truck then consider headers( but like Cool-it said quality headers cost money, cheap ones often take a lot of maintenance ) How much money do you want to spend? Fitment and ground clearance issue to consider with headers. Headers often are louder! Can be annoying on longer trips. If going with manifold, I alway have used ones milled flat on the head surface. Other wise you can have exhaust leak issues. Hope this helps you make your decision. Headers have their place, however, manifold are simpler, and....... Les |
#18 |
Manifolds will last longer with less headaches and headers are ideal on high HP motors where every ounce of air coming in is matched with an exhaust system that blows it out. Not saying you may not have any gains but not worth the peeformance vs price and satisfaction. If me, KISS method; keep it simple stupid.
#19 |
One thing I can say about at least my headers were that they were difficult to seal at the collector. I went through several different applications of gaskets until I found one that worked. Edelbrock doesn't sell the gaskets by themselves.
#20 |
Thanks guy's, I really appreciate your input on this subject. I've got headers on it right now, and it is a daily driver, so like a couple of you have said they can be a bit on the noisy side. Since I'm running a SM465 with 373 rear, anything I can use to tone the noise down in the neighborhood at 4am in the morning might make my neighbors a little more happy.. LOL So it's off to pick n pull to find me a set of manifolds on the first warm day i get.
#21 |
I have been VERY happy with these header and collector gaskets: http://catalog.remflex.com/
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#22 |
Active Member
![]() Join Date: Oct 2012
I do know one thing.. and it's on this truck i just baught.. it has headers put on from the previuos owner.. and that i had to change a starter on it and the only way to get it out was to take the bump stop off on the passenger side..now with manifolds never had that probem.. would i change them out..nope sounds too nice.
#23 |
My truck had headers on it when I bought it and I am too lazy to change them. It has quiet mufflers though and nobody knows the headers are on there. When my exhaust rusts off and IF I have a good set of manifolds around I would probably run manifolds.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#24 |
I run headers on everything I've ever owned. I use quality Aluminum gaskets and they do not leak. I run 2.5" exhaust all the way out back and it gets pretty quiet for having Flowmasters. Some motors are loud no matter what you put on them. High compression and cams and big bores are just louder at the other end cuz so much flow is coming out of them. My 406 sounds like a big block because basically it is. Flows like a mutha when I get on it. Cross pipes can help a lot with sound as well. I had glass packs and turn downs on my 67 Firebird (Chevy 350) with a cross pipe and damn thing would set off alarms on cars with the bass drone coming from it but I could rev it up next to a cop and they would not even look over at me.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#25 |
Headers, headers, headers.
Exhaust is scavenged properly, exhaust valves will love you for it. But if you don't want the additional power and want the easy way out, just go with manifolds. |
