12-01-2014, 12:50 PM | #1 |
Exhaust thoughts
My 70 has a major exhaust leak. It has the original ram horn manifold. The PO replaced the rest of the system with glass packs. It looks like there maybe a crack in the down pipe coming from the manifold. Should I replace the manifold or just the down pipe? Thoughts fellas?
12-01-2014, 01:18 PM | #2 |
Re: Exhaust thoughts
If the manifold isn't cracked or warped, I see no reason to replace it.
12-01-2014, 03:10 PM | #3 |
72 GMC
I have stock manifolds and glass packs
quiet in the cab and outside sounds good goiing down the road why mess with a good thing ? good luck and spend the money someplace else.
KEL Members I have met : 2014.02.01: bruceman1968, Mr Handy, colgad, RenoKeene, CaptRMW |
12-01-2014, 03:11 PM | #4 |
72 GMC
by the way
WELCOME !
12-01-2014, 04:23 PM | #5 |
20' Daredevil (Ret)
Yup, just replace the cracked downpipe.
12-01-2014, 06:47 PM | #6 |
Welcome to the forums, just replace the down pipe.
12-01-2014, 07:59 PM | #7 |
Can you see a crack in the down pipe or is that where the sound is coming from?
The down pipe probably has a doughnut gasket on it and it could be loose, blown or completely missing. Have you tried just tightening the pipe at the manifold?
Terry Soon to be retired and moving to Bristol, TN. |
12-02-2014, 12:53 PM | #8 |
Thanks fellas, I will investigate further.
12-02-2014, 04:44 PM | #9 |
Ram horn manifolds are generally regaurded as high quality , high performance manifolds , work well and are worth keeping
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
