Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 12-01-2014, 09:21 PM   #1
Pro Performance
Pro Performance's Avatar
New! Baer ReMaster Master Cylinder
Baer has finally released their new Master Cylinder, and will be available January 1st, with pre-orders being available. There is an option to add the prop valve mount right into the bottom of the master, along with multiple finish options to match your truck. One of the nicest master cylinders around, and is fully machined in the USA.
  • Compact billet body makes fitment easier while providing the high performance BaerŪ is known for
  • Engineered for optimum balance between pressure and volume for great braking performance with reasonable brake-pedal effort
  • Fully machined body with bolt-on mount and screw-on billet caps
  • Available with and without Baer billet adjustable proportioning valve
Contact us for some special pre-order pricing.
http://baer.com/Remaster.html
https://www.youtube.com/watch?v=r3WPS2UPnvw
Pro Performance is offline
Old 12-02-2014, 09:59 AM   #2
Pro Performance
Re: New! Baer ReMaster Master Cylinder
Old 12-04-2014, 11:05 AM   #3
Pro Performance
Ttt
Old 01-05-2015, 11:20 AM   #4
Pro Performance
TTT. Here is a picture of the standard industrial gray finish with black top.
Old 02-27-2015, 10:31 PM   #5
Gipper01
Gipper01's Avatar
Hi Travis, that's a really nice looking Master Cylinder from Baer. Are there any mounting challenges with the master cylinder for our 1967-72 C10, particularly for those with a Dropmember. Also, would you happen to have any pics of the Baer billet adjustable proportioning valve. Perhaps I'll pull the trigger on this setup if it doesn't pose unique mounting/installation challenges.
Thanks in advance for the response.
Gipper01 is offline
Old 03-02-2015, 11:27 PM   #6
Pro Performance
Baer did a really nice job on this master, and very well though out. It does mount up on a 67-72 without issues, and can be used with or without a booster. I will be using one on my truck with the drop member. I found I needed a 9" booster to clear the LS coil packs on the valve covers.
Here is a picture of the Baer prop valve.
Old 03-02-2015, 11:28 PM   #7
Pro Performance
Old 03-10-2015, 11:27 PM   #8
abraham.hd
Nice.
abraham.hd is offline
Old 03-11-2015, 07:41 PM   #9
Pro Performance
Thanks.... Baer did a really nice job on this master cylinder.
Closed Thread
