Old 12-01-2014, 10:30 PM   #1
T and S
T and S's Avatar
Door weather strip gasket glue
Putting new door weather strips on, trying to get the old glue off. Worked all day and only got about half of door done. Any one have any good ideas to get the old glue off ?
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 12-02-2014, 08:17 AM   #2
cooperhw
cooperhw's Avatar
Re: Door weather strip gasket glue
Five gallons of gas and a match will do the trick.
Just kidding.
I usually use thinner, scraper, sweat, a little blood always helps, and a dose of persistence. Stuff is a bear. No doubt about it.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 12-02-2014, 10:20 AM   #3
WhippinSaw
WhippinSaw's Avatar
I haven't tried it for glue but bug and tar remover might work, wd40 also cleans up painted areas, a heat gun at lowest setting to not affect the paint might help
Good luck
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 12-03-2014, 12:07 AM   #4
T and S
T and S's Avatar
tried the heat gun, no help. Been picking at it with a dull pocket knife, works, but slow.
Old 12-03-2014, 12:31 AM   #5
Ratpin
Ratpin's Avatar
Try one of these.
Eraser wheel Eraser wheel
Worth it's weight in gold.
"It ain't as easy as Chip Foose makes it look"
Ratpin is offline   Reply With Quote
Old 12-03-2014, 11:07 AM   #6
64shortbox
64shortbox's Avatar
T and S Are you using the Honda door weather strip? If so and the old adhesive didn't get up past the pinch seam the Honda weather strip will cover the old glue. I didn't bother to remove any of the old adhesive off my door frame and the Honda weather strip covered it all. The Honda weather strip has an additional finish piece that covers very well.
64shortbox is offline   Reply With Quote
Old 12-03-2014, 11:35 AM   #7
schpeen
schpeen's Avatar
you have to use oil to get that off if you really want it off. I use regular cooking oil.
schpeen is offline   Reply With Quote
Old 12-03-2014, 04:35 PM   #8
63 & 64 Bowties
and a few others
I've used this stuff with good results. Most auto parts stores carry it.
It's actually made for getting bumper sticker glue off of painted bumpers. It still takes some elbow grease but it gums up the glue so it's easy to get off.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 12-03-2014, 06:38 PM   #9
duallyjams
duallyjams's Avatar
I just installed the Honda door weather strip and left the old glue on there and can not see it.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
