Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 12-01-2014, 10:41 PM   #1
drillrod
WTB-Under dash speaker brackets
I am looking for the brackets that holds the speaker on the bottom lip of the dash under the AC controls. I have got two that i got from another member but they have a nut welded on each one of them and i can`t get them to work! I dont know if they were for non AC or not! I have seen the ones on this forum without the nuts and that is what I am looking for. Thanks
drillrod is offline   Reply With Quote
Old 12-03-2014, 10:47 PM   #2
drillrod
Re: WTB-Under dash speaker brackets
Anybody!
Old 12-04-2014, 04:22 AM   #3
bluek5
bluek5's Avatar
Can you grind the nut off? I think I have one without the nuts. I will look and post a picture if I do. I am not trying to sell it though. Do you want to sell one of yours that wont work?
Paul
bluek5 is offline   Reply With Quote
Old 12-05-2014, 04:06 PM   #4
drillrod
It takes two brackets to hold the speaker and that is all I have. That is a possible idea if I cant find the correct ones. I would like to see a picture of yours if you have one.I would be willing to trade mine for the ones like I need, thanks.
Old 12-05-2014, 05:42 PM   #5
bluek5
bluek5's Avatar
Oh, ok I was thinking that you had two speakers. Here are some pictures of mine.
Paul
Old 12-06-2014, 04:36 PM   #6
drillrod
That is exactly what I am looking for! If you decide to sell yours, please let me know. Maybe someone else will respond that has some, thanks.
Old 12-06-2014, 08:39 PM   #7
briank
Hard item to find. I sold a speaker to a member here and they had the different brackets than what he needed and he was looking to trade awhile ago. I do not remember which brackets it had but more than likely its the same as what you have. His name was luisg (or similar,ill check my pm's) Those dont look too hard to make though.
briank is offline   Reply With Quote
Old 12-06-2014, 08:43 PM   #8
briank
Luis gz 06 is his id
Old 12-07-2014, 10:11 AM   #9
drillrod
Thanks, that is probably what I will have to do is make them!
Old 12-08-2014, 04:32 PM   #10
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
I have this mounting bracket that came with the same brackets that you have don't no how it worked I didn't take it off.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 12-08-2014, 09:54 PM   #11
drillrod
I have never seen that bracket before. Do you know what year model it came off of, or if it had AC!
Old 12-09-2014, 05:07 AM   #12
Classic Bowties
Always on the hunt...
The below pictured bracket that I highlighted in yellow from Gary 70 Jimmy's above post would've been from any 67-72 that was originally AC equipped. The bracket was used for mounting the AC type heater controls to the lower lip of the dash, this same AC heater control had a few other earlier GM applications using a 5 & 1/16" mounting hole spread, our 67-72 GM trucks have a 6 & 7/8" mounting hole spread and this highlighted bracket solved the hole spacing difference. GM was then able to use a part that was already produced and in use for a couple of years prior to 67. Mel
Classic Bowties is offline   Reply With Quote
