Old 12-01-2014, 11:10 PM   #1
dyablo2014
5.3 swap
I Have A 65 Trying To Do A LS Swap But I Need More Info. Can somebody
Guide me to the right direction.
Can I use the original mounts
Headers
Etc.. thanks guys.
dyablo2014 is offline   Reply With Quote
Old 12-01-2014, 11:41 PM   #2
NevEno
NevEno's Avatar
Re: 5.3 swap
I'm in the process of doing one myself in my 64 c10. I bought a kit that comes with motor mounts headers and trans crossmember..
NevEno is offline   Reply With Quote
Old 12-02-2014, 12:47 AM   #3
dyablo2014
Re: 5.3 swap
Where did u get it? Who makes it
Thanks in advance
Old 12-02-2014, 02:08 AM   #4
NevEno
NevEno's Avatar
Re: 5.3 swap
I got mine from Classic performance products it was $869.
http://www.classicperform.com/Store/...e_Upgrades.htm
Old 12-02-2014, 03:29 AM   #5
Chevysdominate
Chevysdominate's Avatar
Re: 5.3 swap
In the engines section of this site is a lsx swap section. This might help a little.
http://67-72chevytrucks.com/vboard/f...play.php?f=206
Chevysdominate is offline   Reply With Quote
Old 12-02-2014, 08:29 AM   #6
dyablo2014
Re: 5.3 swap
Thanks. That's a little over my budget. I'm trying to find
I'm going to check out the lsx swap section. Thanks.
Old 12-02-2014, 08:49 AM   #7
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 5.3 swap
Look at the FAQ in that section, several ways to skin that cat.
If inexpensive is what you want. You "can" use the stock perches, however it is tough to get the bolts in the mounts!!!
I suggest some 73 up perches ( Called Clam Shell) and some dirty dingo slider mount plates, SBC motor mounts, then a CPP tubular trans mount ( unless your going with a different trans that the 4l60e)
Im up the road, just north of Burleson if you need more info.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
