Four Link
I have been looking at doing a 4 link on my 1965 Chevy Pickup. I found a site that might make it more economical. Anyone done a 4 link on a 60-66 C10.
************* Last edited by aspiringthomas; 12-02-2014 at 12:14 PM. Reason: spelling |
Re: Four Link
![]() Join Date: Jan 2011
Re: Four Link
There prices on some stuff is very high. There front cross member is $1,000,000 plus bags and sway bar. Stuff looks OK I am just not a fan of 100% non adjustable links. If anything pulls in the housing when you weld it (and it will move) you have no way to get the preload out of the system.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Re: Four Link
ive always bought the 4 link ends with bushings from thorbros and made my own. i buy a grade 8 bolt and nut weld the nut to the bars and the bolt to the bushing to make it adjustable. im in the process of doing it again but im making a 3 link this time
Re: Four Link
you can also buy it with the thread already on like these
Re: Four Link
Thanks. Also considering using coil over shocks. I wonder where is a good place to find a bargain on them.
Re: Four Link
I used peices from ballistic fab. Very nice parts bought the weld in bungs uppers are round and fully adjustable left and right hand thread. And the bottom is adjustable on one end only. The shanks for the bushings are 1 1/4 on the bottom and 7/8 I believe for the top
Re: Four Link
Here is a complete bar pic
Re: Four Link
Here is a shot of one side
Re: Four Link
Re: Four Link
The tubing is from a local steel distributor. The lower links are 2x2x1/4. And the upper links are 1 1/4 round and the thickness was just under 1/4
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Four Link
Don't cut corners on something as critical as suspension links. Get the right parts and make sure the welds have good penetration. The components that lowlife4life used from Ballistic Fab are very good quality.
http://www.ballisticfabrication.com
#13 |
Re: Four Link
AVS or AZProperformance can you get a 4 link for just about the same price as making it.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
