![]() Join Date: Jan 2012
Dash panel
How do you remove the dash panel after you take the bolts out on the sides?
Re: Dash panel
It is welded in place. You drill out all of the spot welds along the windshield opening
"Negative people always seem to have a problem for every solution" |
Re: Dash panel
Thanks for info I have one to take out
![]() Join Date: Oct 2004
Re: Dash panel
What I would do it take the dash pad off and cut the dash along were the pad sits and weld in the replacement dash. That way you don't have to remove the windshield.
Steven 69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners ![]() 2017 50th Anniversary Camaro SS 2004 Chevy Impala LS 2016 Chevy Malibu LT |
![]() Join Date: Dec 2013
Re: Dash panel
the three bolts on ends are for positioning , then you have to drill 34 spot welds out and its free , windshield removal required
![]() Join Date: Sep 2007
Re: Dash panel
Ir if youre taking one outnof a junk truck just sawzall it out and clean it up ( drill spotwelds) when you get home
1967custom |
