12-03-2014, 02:17 AM | #1 |
Tire Size Lowering 69 C20
I will be running 16 x 6.5 wheels and I was wondering what size tires your guys are running... going to run the 2/4 drop kit...Thanks
12-03-2014, 01:17 PM | #2 |
Re: Tire Size Lowering 69 C20
What size tires are on it now? Do you plan on using it like a truck? IE: do you need load capacity or are you considering passenger car tires? What gears are in the truck and do you need tire height to knock the RPM down?
On my 70 C2500 GMC I left it stock in front and did 1 1/2" lowering shackles in the rear. (Leaf spring truck) With 265 75 16 on 16x8 inch Alcoa rims. I had 3.54 gears in the Dana 60. My truck was a 7500 GVWR truck (maximum for the platform) with a big block and air so it had the heaviest rated springs for a 2500. Keeping in mind it's a 3/4 ton truck, I'd go with 215 75 16 or 225 75 16 tires with at least a D rating in your case. 215's gives you about a 28 1/2" tire height compared to the 31 1/2" height on my 265's.
12-03-2014, 02:49 PM | #3 |
67 C20 stock height with 245 75 16.
12-03-2014, 03:04 PM | #4 |
I ran into very few choices for wheels and tires with stock 16.5's so went to a 17' wheel...lots more choices now. Still a hauler but I can put larger tires on rear. Good luck with your choices.
benner Blacked out 1970 CST, C 20. Hardcore Work Truck with 350, Edelbrock 750, RPM High Rise, Flow-Masters, Black wheels and a Log Wood Rack. One Hot Worktruck. |
12-03-2014, 07:57 PM | #5 |
My info is in my signature if your interested. Good Luck!
1968 Custom Camper C/20, rebuilt original 327 with 350 hp., turbo 400 with shift kit, factory AC truck, original patina rust free paint from Oregon, 2/4 lowering springs + 1" blocks, GM 2500 8 bolt rally's with dually center caps with Firestone Destination 245/75-R16's. (My 50th birthday present from my wife!!!) |
12-03-2014, 11:35 PM | #6 |
225-75R16, load range E, got the tires for free and like the size on the truck. One coil cut from the front big block springs that are now supporting a 350, about a 2.25" shackle drop in the rear. Might pull a leaf out of the rear to level it a bit more. The first pic is right after chopping the springs.
71 C-20 Custom Deluxe 350-TH400 Blue/white standard two-tone 92 K1500 350-4L60 Blue/white two-tone Last edited by JustinGJ; 12-03-2014 at 11:42 PM. Reason: Added pic. |
12-06-2014, 04:33 PM | #7 | |
12-06-2014, 05:28 PM | #8 |
Im running 235/65/16 in front and 275/60/16 in the rear. 5/7 drop.
1969 CST/20 396/TH400 Tach Posi |
12-06-2014, 07:19 PM | #9 |
Nice looking truck...
12-06-2014, 08:13 PM | #10 |
Decide if you want to keep truck tires on it or passenger tires is the first step. I don't think a tire shorter than 28" looks right on these trucks keeping this in mind.
12-06-2014, 10:37 PM | #11 |
I like this stance.....
12-07-2014, 12:06 AM | #12 |
Thanks gt40!
I used to have those wheels too
12-07-2014, 10:07 AM | #13 |
1969chev, how did you get it that low? What is your rear end gears? I'm kind of limited with 4:10 gears so I need a taller tire.
12-07-2014, 10:44 AM | #14 |
67 GMC bone stock height, "Kirkland Signature" 235/75R15 M+S. All the way around. I bit bouncey
Hey man 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 Last edited by Oregon 1967 GMC; 12-07-2014 at 10:52 AM. |
12-07-2014, 02:15 PM | #15 |
Well my truck has factory 4.10s, I'm the 2nd owner but i think the 1st owner swapped the 4.10s with 3.73s. And i have 3 inch lowering springs with a full coil cut in the front, and 5 inch lowering springs out back with 2 inch blocks. I dont have a c-notch, but i sometimes hit my axle on my frame.
