Old 12-03-2014, 04:09 PM   #1
coop34
Brake Hose Help
My brake hoses are way too long (See pic). My calipers and hose are from a 78 C10 which have different fittings and length than the 72 C10's.
78 C10 Hose:
End 1 Thread Size: 0.44 Inch
End 1 Type: Banjo
End 2 Thread Size: 5/8-18, 3/8-24 Inch
End 2 Type: Male, Female
Total Length (In): 22-7/8 Inch
72 C10 Hose:
End 1 Thread Size: 7/16-20 Inch
End 1 Type: Male/Female
End 2 Thread Size: 7/16-24 Inch
End 2 Type: Female
Total Length (In): 13-1/4 Inch
Does anyone know of a shorter hose with the correct fittings for my calipers? Or is it possible to just shorten the hoses I have?
Coop34
70 Chevy C10 5.7L TBI/700R4
coop34 is offline   Reply With Quote
Old 12-03-2014, 04:34 PM   #2
kuch72
Re: Brake Hose Help
What year is your truck? Is it a 1970 with discs from a 78? On a 1972 1/2 ton the brake hose comes to the front side of the front crossmember and mounts to a bracket that it looks like is missing from your truck.
kuch72 is offline   Reply With Quote
Old 12-03-2014, 04:42 PM   #3
coop34
Re: Brake Hose Help
Yes a 70 with 78 discs
Coop34
Old 12-03-2014, 05:35 PM   #4
ultrahd4me
ultrahd4me's Avatar
Re: Brake Hose Help
I don't have the part numbers handy but do a search here on 72 elcamino front brakes hoses. That's what I used, and its the same as the drum brake conversion hoses sold by a few of the venders. They use a 7/16 banjo bolt, 3/8-24 thread, and only 12" long.
Follow me on Instagram: @midtennc10
Youtube channel: Midtennc10
ultrahd4me is offline   Reply With Quote
Old 12-03-2014, 05:48 PM   #5
ultrahd4me
ultrahd4me's Avatar
Re: Brake Hose Help
Here you go. Napa part# UP 36616
Old 12-03-2014, 05:55 PM   #6
ultrahd4me
ultrahd4me's Avatar
Re: Brake Hose Help
Here is AutoZone part# and info:
Part Number:
88466
Weight:
0.25 lbs
Warranty:
1 YR
Application:
With disc brakes
Notes:
Fits either side
May require hose lock replacement, part number H1457A
Brake Hose Length (in):
11.875
Fitting Material (1):
Treated Steel
Fitting Material (2):
Treated Steel
Fitting Size (1):
Banjo - 0.4375
Fitting Size (2):
Female - 3/8-24
Gaskets Included:
Yes
Hose Material:
EPDM Rubber
Item Grade:
Standard Replacement
Package Contents:
Brake Hose, Gaskets
Old 12-03-2014, 11:07 PM   #7
coop34
Re: Brake Hose Help
Thanks ultra. Stupid question..what is a male,female fitting? and why are two sizes listed? (5/8-18, 3/8-24 )
Coop34
Old 12-04-2014, 12:36 PM   #8
coop34
Re: Brake Hose Help
I'm referring to the 78 C10 Hoses. They say the fittings are:
Not sure what this means? The fittings are a he/she?
Coop34
Old 12-04-2014, 12:53 PM   #9
ultrahd4me
ultrahd4me's Avatar
Re: Brake Hose Help
I think the 5/8 is the hex size and the 3/8 is the inside thread size.
Old 12-04-2014, 01:48 PM   #10
coop34
Re: Brake Hose Help
Gotcha. Sounds like it should work. I'll give it a shot. Thanks again for your help.
Coop34
Old 12-04-2014, 03:15 PM   #11
70CHEVYBB
70CHEVYBB's Avatar
Re: Brake Hose Help
SIMLPE: Buy the hoses for your year truck and where the hose mounts to the caliper put a new notch for the metal line to set in in the right direction. I just did something similar on my 70 and works great.
70CHEVYBB is offline   Reply With Quote
Old 12-04-2014, 03:46 PM   #12
coop34
Re: Brake Hose Help
Thanks 70chevybb. I will definitely do that. However, my main problem is the fittings are different.
Coop34
Old 12-05-2014, 11:47 PM   #13
70CHEVYBB
70CHEVYBB's Avatar
Re: Brake Hose Help
You just make a make a new brake line with the correct fitting I bought two hoses and they were different. Just use the right fitting. Any auto parts store will have them
