Old 12-03-2014, 09:57 PM   #1
mango
Lift kit/ frame problems?
I am building a 69 swb stepside chevy 4x4 with a 6 inch skyjacker lift. I have a 70 cab and 69 front end and box (asuming they are basicly the same from 69-72) but I am running a 67 swb 4x4 frame. The question I have is what exactly is the differences between the 67 frame and the other years? I know about the power stearing box dimple and found out the hard way that the body mounts are different, but when I put the bed and lift on i found out the rear axle was about 3 inches too far forward. So I ended up having to relocate the front spring perches back to center the wheel I go the rear wheel wells. Now I am noticing that the front axle is also too far forward by about an inch and a half and has to be relocated back to center the axle in the wheel well. Also I can turn the wheels right untill the tie rod hits the diff cover but they only turn left a little bit before the stearing box limits out. If anyone has any info or has lifted a 67 and has any advice I would appreciate anything you've got. As of now I am looking for a 69-72 swb 4x4 frame to do a swap if I have to.
mango is offline   Reply With Quote
Old 12-03-2014, 10:06 PM   #2
swamp rat
swamp rat's Avatar
Re: Lift kit/ frame problems?
Probably have more answers in the 4X4 section..
You should also mention of its a K10 or K20.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-03-2014, 10:30 PM   #3
mango
Ok thanks. I'll try there, but it is a k10.
fram, lift kit
