BAD BOW-Silverado XST
C-notch without a flip kit - anyone?
Is anyone using a C-notch kit on their truck without a flip kit on the axel? Including a shackel and hanger 4" drop too?
I'm deciding if I need to purchase a flip kit. Currently I have a shackel/hanger combo installed for about 4". Since I'll be adding a 1.5 coil to the 2.5 spindal in the front I want to keep the truck level. So I need at least a 5-6 drop in the rear. I have 4" lowering springs plus the shackel/hanger combo on the truck now. Plan is to notch the frame add the leaf springs and raise the rear shackel for about a 5-6 drop. Oh, BellTech C-notch kit in the mail!! ![]() ![]() Mike, I was looking at your c-notch kit installation. Even adding the weight of the bed, it looks like there is enough travel without the flip kit. Does it look possible? |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I have a bell tech flip kit on ebay right now.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2427881215 Belltech told me a Blazer doesn't need a c notch to be flipped. They recomend the truck get a notch though. My auction is for the flip kit only.....
You get what you pay for
![]() Join Date: Dec 1999
How do you have 4" leafs and a shackle hanger combo on it now? This would give you 8", right? When I had the 4" leafs on and a shackle, with stock hangers, it was around 5" of drop.
Anyway, after going to a full 6" of drop, I had 2-3/4" left from top of axle to frame. Not enough. It would hit on big dips.
Mike 1985 Chevy C-10 |
I have a shackel/hanger with stock springs on now. Sitting in the garage are 4"drop leafsprings. My idea is to notch the frame add the 4" leafs then take the shackel up one bolt hole. How close will that be to needing a flip kit? I prefer not to install one since I would like to keep the traction bars too.
Mike what is the measurement from the center of rear wheel to the wheel well? |
Let's say if you move the shackle to the shortest hole on a shackle and hanger kit, it would be in the 3" drop range. If you add 4" leafs, this should be around 7".
With a flip, it varies, depending on what hole in the shackle you use. Anywhere from 5" with stock shackle, up around to 8" with the upper hole in the drop shackle. My truck measures 13" from wheel center to fenderwell lip on the rear and 14-3/4" on the front. This puts it level since there is around 1-3/4" difference in fenderwell height. |
#6 | |
www.73-87chevytrucks.com
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
