Old 12-04-2014, 07:11 AM   #1
Boog
laying low
Boog's Avatar
headlamp bulbs don't last long
We've got an 03 Tahoe and are replacing headlamp bulbs way too often. We are using Sylvania bulbs and we are having to replace one side or the other about every 5 months. No other light problems. Any ideas what would cause the rapid failure rate?
I use the same brand bulbs in my 2000 GMC and do not have this problem.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-04-2014, 07:39 AM   #2
ssxty8
Re: headlamp bulbs don't last long
Humidity inside the headlamp assy? Alternator charging too high? Vibration due to loose headlamp assy?
Just my 2 cents.
Good luck.
ssxty8 is offline   Reply With Quote
Old 12-04-2014, 11:21 PM   #3
Tropical Snowstorm
Lurky lurky
Tropical Snowstorm's Avatar
Moisture intrusion would be my guess as well. Make sure you do not touch the bulb itself too, I always put on a pair of nitrate gloves to prevent oils from the skin messing it up.
Tropical Snowstorm is offline   Reply With Quote
Old 12-05-2014, 11:39 PM   #4
Boog
laying low
Boog's Avatar
I have not noticed moisture accumulation inside the lamps and I am aware of the clean touch issue. Alternator output looks to be normal. These headlight bulbs are the only ones with the shortened life. I might look at the ground wires.
Boog
primer is finer
