Old 08-18-2003, 09:45 PM   #1
72longbed
72longbed's Avatar
All You Drop Experts!?!?
Calling all Droppers!!
How will new 2" drop springs made for a 1/2 ton work out on my C-20? Will they handle the extra weight of the heavy 8 lug spindle assembly?? Will it ride like mush if I don't use 3/4 ton front springs? Can the front end still be accuratly aligned with a 2" spring only drop? What other considerations do I need to know before I do it? Thank you for the input and advice!!
72longbed
72longbed is offline   Reply With Quote
Old 08-19-2003, 09:23 PM   #2
72longbed
72longbed's Avatar
Don't nobody have no o-pinions?? Come on, what gives?
Old 08-19-2003, 09:36 PM   #3
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I wouldnt want to spend the money to find out!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 08-23-2003, 01:58 AM   #4
chevykid04
4 speed, hurst shiftin
chevykid04's Avatar
i would suspect a mushy old caddy ride and possibly worse ability to hold a corner?
Shane
1970 Chevy C10
chevykid04 is offline   Reply With Quote
Old 08-23-2003, 03:56 AM   #5
Alexis
Member since 2000
Alexis's Avatar
I know a few guys have done this and they are on the board. If I'm right I think they didn't find any problems with the setup. Just cause it's 8-lug doesn't change much since all it is, is heavyer duty parts compare to a 1/2 ton. If you have a leaf spring setup in the rear then all you need to do is a flip kist and a shackle to get the rear lower. Yeah, a c-notch might be in order for the rear suspension.
Alexis is offline   Reply With Quote
Old 08-23-2003, 09:38 AM   #6
72longbed
72longbed's Avatar
Alexis,
Thanks for the response. I'll probably be using the ECE Rear Air Bag Kit, (it has coils in the rear now), to give me a lower stance and still maintain the carrying capacity when I need it. Any experience with their Bag Kit?
72longbed
