Old 12-04-2014, 05:59 PM   #1
carlrmartin
1964 C10 3-Speed to Super T10 Swap
I am seeking help and information on a swap from a 3-Speed (Borg Warner non-syncro 1st) in my 64 to a 1978 Super T10 (yes I now about overdrive and have done that before, just going old school on this project).
The truck was converted to a 74 350 before I got it but still has factory bell-housing and 3-speed.
1) Can I use the same Bell Housing?
2) Does it require any machining?
3) Clutch, Pressure Plate ?
4) Throw-out bearing?
Anyone need/want a three-speed? I was told it was rebuilt just before I bought the truck and it's going to keep my old T350 company out back.
carlrmartin is offline   Reply With Quote
Old 12-05-2014, 02:07 AM   #2
Captainfab
60-66 Nut
Re: 1964 C10 3-Speed to Super T10 Swap
1) Yes you can use the original bellhousing and just hang the trans off of it as the 3 speed is.
2) There shouldn't be any machining necessary.
3) A '78 Super T10 should have a fine spline input shaft, so I would go with a clutch for say a '78 Z28.
4) The same application for the TO bearing, '78 Z28.
Old 12-05-2014, 03:22 PM   #3
carlrmartin
Thanks - i was pretty sure this was the case but couldn't confirm it. I got a sweet deal on the ST10 so should be a real budget saving move.
I put a new clutch pack in the truck recently, so it's a new pressure plate, any need to replace it?
Old 12-05-2014, 07:43 PM   #4
DURG
DURG's Avatar
You will need a different driveshaft yoke too.
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 12-06-2014, 03:35 AM   #5
Captainfab
60-66 Nut
The pressure plate should be fine as long as you can find a disc the correct diameter with the fine spline for the ST10.
st10 transmission
