Old 12-04-2014, 06:04 PM   #1
LVPhotos
LVPhotos's Avatar
Sun visor FAQ
Went to install sun visor on passenger side where that was not checked as option. Use the dimples and it was off. Used the Yellow Assembly Manual and the dimple is for the 1.25" hole. Just assumed the other is for lower one. Waiting on drill to charge for next round. Here is the page for reference.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 12-04-2014, 07:33 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Sun visor FAQ
Installed.
Old 12-05-2014, 04:11 AM   #3
Grizz1963
Grizz1963's Avatar
Re: Sun visor FAQ
Now I know, I really need to find one to buy.
I like that a lot.
It's a useful extra.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 12-05-2014, 11:41 AM   #4
LVPhotos
LVPhotos's Avatar
Re: Sun visor FAQ
http://www.brotherstrucks.com/prodin...number=LFA6066
Old 12-05-2014, 03:29 PM   #5
Grizz1963
Grizz1963's Avatar
Re: Sun visor FAQ
I like that a lot.
The sun visor, that is.
Old 12-05-2014, 03:51 PM   #6
Kenfuzed
Kenfuzed's Avatar
Re: Sun visor FAQ
Interesting, those look longer than the ones that came on my 66 C10. The mounts are the same but my visors don't stretch that far toward the center.
Of course there's always the low-tech method
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 12-05-2014, 03:59 PM   #7
LVPhotos
LVPhotos's Avatar
Re: Sun visor FAQ
I said the same thing. But that is the parts they sent. The mirror head is bigger as well and GM approved. There is a tab on the arms inch from 90 not sure it goes that far. I forced them on as far as they would go.
Old 12-05-2014, 04:05 PM   #8
Kenfuzed
Kenfuzed's Avatar
Re: Sun visor FAQ
Perhaps mine are just short or the slide on portion was from another vehicle. Looks good.
Enjoying the ride!
Old 02-22-2016, 01:40 AM   #9
sharkskinman
Re: Sun visor FAQ
Bump thread
Just got passenger visor
Was thinking for placement I would remove the drivers one and tape off section from windshield to door and to separation of A pillar
Then flip and drill
Also got rear view mirror but might mount as dash mirror(Muppets woody) who knows
Don't really need one with small window but looks cool
sharkskinman is offline   Reply With Quote
Old 02-22-2016, 02:03 PM   #10
jbgroby
jbgroby's Avatar
Re: Sun visor FAQ
I just recently did mine.
jbgroby is offline   Reply With Quote
Old 02-22-2016, 03:40 PM   #11
sharkskinman
Re: Sun visor FAQ
How did u go about placement?
Old 02-22-2016, 04:23 PM   #12
jbgroby
jbgroby's Avatar
Re: Sun visor FAQ
I have a template from anotherembwr, I can look for it if needed
Old 02-22-2016, 05:27 PM   #13
Brad54
Brad54's Avatar
Re: Sun visor FAQ
So do I understand correctly that the dimple that's there is NOT the reference mark for drilling the passenger side mount??
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 02-22-2016, 06:14 PM   #14
sharkskinman
Re: Sun visor FAQ
Yes template would be great!
Old 02-22-2016, 07:00 PM   #15
65chevysub
65chevysub's Avatar
Re: Sun visor FAQ
Sorry to break in on this thread but how do I keep the visors from coming down with vibrations and such? I have a velcro tab glued to the header panel and a matching tab stapled to the visor...did this several years ago, but they still keep coming down.
Thanks for any tips
65chevysub is offline   Reply With Quote
Old 02-22-2016, 09:52 PM   #16
racecougar
racecougar's Avatar
Re: Sun visor FAQ
Thanks for any tips
Slightly bend (gentle arc) the visor rod inside the visor.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 02-24-2016, 09:45 PM   #17
65chevysub
65chevysub's Avatar
Re: Sun visor FAQ
Thanks. I will slightly bend the rods.
Old 12-14-2020, 07:37 PM   #18
Vortech
Vortech's Avatar
Re: Sun visor FAQ
I need a copy of the template to install a passenger side sun visor.Thanks
Vortech is offline   Reply With Quote
Old 12-14-2020, 08:34 PM   #19
66x3
Re: Sun visor FAQ
I recently did mine and drilled the big hole first , stuck it up in there and then marked holes for screws, They are for sure not exactly where the dimples are.
66x3 is offline   Reply With Quote
Old 12-15-2020, 01:13 PM   #20
jbgroby
jbgroby's Avatar
Re: Sun visor FAQ
From the factory install guide, I'll try to find the template I have
Old 12-15-2020, 09:24 PM   #21
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Sun visor FAQ
Or you could use the drivers side, Make a Template and transfer it to the passenger side.
Old 12-16-2020, 10:28 PM   #22
Vortech
Vortech's Avatar
Re: Sun visor FAQ
great thanks
Old 12-18-2020, 01:39 PM   #23
hairball
Re: Sun visor FAQ
Good morning all, I also have to drill the holes for the passenger side and I am in search of a pair of visors for my 65. Has anyone used the Dave Graham visors from RockAuto? I would like something close to the original. My driver side is brown in color, not sure if that's correct. I think it's original. Thanks for all the information, have a great weekend.
hairball is offline   Reply With Quote
Old 12-19-2020, 11:00 AM   #24
88Stanger
88Stanger's Avatar
Re: Sun visor FAQ
just to add to this.. I had to replace that inner panel due to rust. So i order the entire panel, runs from driver to passenger side. I comes with only 1 hole for the driver side, none on the passenger side. I was able to keep my original placed one and use it.
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
