90s vortec distributor on an older sbc???
Hey guys, I used to have a 96 tahoe and one of the things I liked about the engine was the corrected distributor cap (2468 on the left 1357 on the right) I know they make these caps for older hei distributors, but I was wondering if anyone has ever put a distributor from the late 9ps vortec motors on an sbc? They are fairly available at most junk yards and cheaper than the hei system s from summit
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding ![]() My build : 68 C10 Short Bed Conversion |
![]() Join Date: Dec 2012
Re: 90s vortec distributor on an older sbc???
Since I can't see any pictures pretty sure the vortec distributor will have no mech. advance so unless your running a good EFI system it won't work
'77 P10 (GMs late 60s thru the 70s truck spare parts bin model ![]() |
The 95/96 Vortec distributors are plastic and prone to short lifespan. I think you're way better off with the good old HEI. It's a common upgrade to install the '97-up induction/ign on 95/96s
Yeah, all the advance [both mech and vac] were gone by the days of the vortec motor. The pcm took what would have been their job so they weren't needed.
The only thing under the cap is a cam sensor so it's pretty useless with any application other than what it came off of.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
Ahh, good point... wasn't thinking about the missing advance. Geuss ill be spending the 45$ for one of those corrected caps from summit after all
![]() ![]() Join Date: Aug 2013
Just a heads up on the Accel corrected cap. I just purchased one from eBay to clean up my existing installation. After trimming the new ignition wires I ran engine (sbc), and set the timing. The next day I fired it up and I had an engine misfire and backfiring so bad I couldn't get it to run at all. After a day of trouble shooting thinking I screwed something else up I reinstalled the stock cap/wires. Now my 62 fires right up with no issues, so I Googled "Accel corrected cap misfire" and found MANY people have experienced this. My buddy uses a "Crossfire brand" for 2 years with no issues and as for me, I'm staying with the stock cap because I don't like walking home....good luck
All about them K’s
![]() Join Date: Jun 2014
Took the words out of my mouth. My 98 has the crappy plastic corrected distributor and it has random misfires on #1 & #3 at idle. I'll change the cap and it goes away for a week or so then comes right back. I've been thru 3 cap and rotor sets,all aftermarket. Delco is going in next and if that don't fix it I may shoot holes In it! Just kidding obviously but it is pretty annoying. The cheapest Chinese hei distributors are a million times better quality than the plastic turd in my vortec 454.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
They're also useful for converting Gen 1 smallblocks to sequential fuel injection - as long as you also add a crank trigger.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
here is an article on converting a hei to use the crab cap. the pics are no longer working but you should be able to get the idea by reading it
http://www.fiero.nl/forum/Forum2/HTML/128175.html
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
#11 | |
![]() I have an MEFI with a Ramjet style intake. I installed a Skip White distributor so it's new and I won't change it but if I had thought about it first I would have installed one of those cool distributors like that. However, if you install one on a flat tappet cam engine, be advised that those distributors are set up for hydraulic roller cam and have a melonized dist gear. Hmm....wonder if I could put that cap/rotor setup on top of my billet Skit White dist that already had the internal module? Food for thought. Last edited by mechanicalman; 12-05-2014 at 07:37 PM. Reason: Got to thinking |
#13 |
So, I wonder what the difference is length wise in the 2 cams. I wonder if I could take a 95+ cam, punch out the pin, install a shaft and gear from an der hei with mechanical advance, and use a rotor from the older distributor and BAM... crab cap? The only issue I ever had with my vortec distributor was that the body was plastic and I once overtivhtened the cap screws and snapped an ear. Maybe ill try an after market crab cap for an older hei
#14 | |
http://www.msdignition.com/Products/...ble_6AL-2.aspx |
