Old 12-05-2014, 01:13 AM   #1
79c25
79c25's Avatar
fuel pump ?
So I have a problem that kinda has me stumped. I recently installed a Mr gasket electric fuel pump 4-7 psi 35 gph in my 79, and it seems like I either have a pin hole in my steel fuel line which is very possible as it is rusty, or the quadrajet carb requires more than 7 psi. Any suggestions would be greatly appreciated. The truck still runs barely but it runs and acts like its starving for fuel and when I shut it of the fuel filter (cheepo clear plastic unit) is dry again then I can bleed the air out and it will run fine til it empties the filter again.
1979 GMC Sierra Grande Crew Cab C25, 454/TH400/4.10-Project truck/ DD
1985 Chevy K5 Blazer 700r4/4.10/8 lug- in search of new engine
1993 GMC Sierra K1500 4L60E
2007 Suzuki Forenza- her DD and the family vehicle
79c25 is offline   Reply With Quote
Old 12-05-2014, 01:14 AM   #2
Gregski
Gregski's Avatar
Re: fuel pump ?
do you have a way of actually testing what the new pump is actually pumping at maybe it is defective, I think all you need is like 3.5, PSI
I would take that fuel pump and bring it closer to the engine/carb and have it pull from a jug and pump straight to the carb with a short rubber hose in order to eliminate your fuel lines as being the problem
guy on YouTube talking about an issue with his
https://www.youtube.com/watch?v=qNZxFYsN7yw
Gregski is offline   Reply With Quote
Old 12-05-2014, 08:10 AM   #3
79c25
79c25's Avatar
Re: fuel pump ?
That was my next step just to see as well as getting a cheap fuel pressure gauge.
Old 12-05-2014, 08:26 AM   #4
79c25
79c25's Avatar
Re: fuel pump ?
I just watched that you tube video and I wish I knew that before getting the pump
